$300 dollars later trailer
#1
Found this little gem that was used for dump runs at a repair shop $27.00 Habor Freight magnetic light kit I was on the hi way going home. 6 x 4 x 3. ATV hauler? mini garage? just living in the city enclosed trailers are a target like " hey I wonder what's inside?" it has happened to me.
Truck Camper in San Francisco
#2
that nice of a trailer is surely holding buckets of gold nugget!
#3
As a kid,  Dad brought something about like that home,  but it was just the frame.   He stripped the wood off it and junked that and built it up about like that photo.  At the front center he had an extension that stuck up about 6 inches with a 1 1/4 inch + hole drilled in it.  The back end had similar.   A length of black pipe went through holes just barely and a threaded porch base screwed on at both ends.  This established a ridge pole
for the canvas cover. (much like a Wall Tent)
I see the sides of the trailer have the fittings for bungee straps to hold the covering on the trailer.  But without a ridge  pole the canvas on that trailer would become a pool.
with these screwed onto the pipe at either end on the outside, the pipe couldn't go forward or backward.  Worked very well.  Inside the Trailer we had plywood boxes as containers so that camp gear was in one, cooking
equipment in another etc.
That was where we started with a Station Wagon before we moved over into Vans.
#4
Lucky you with a handy dad must have been fun my dad was a beatnik artist.
(07-13-2017, 05:19 PM)eDJ_ Wrote: As a kid,  Dad brought something about like that home,  but it was just the frame.   He stripped the wood off it and junked that and built it up about like that photo.  At the front center he had an extension that stuck up about 6 inches with a 1 1/4 inch + hole drilled in it.  The back end had similar.   A length of black pipe went through holes just barely and a threaded porch base screwed on at both ends.  This established a ridge pole
#5
Hope you have better luck with the HF magnetic lights than I did. I back up the magnets with a bungee.
Looks like a pretty well made trailer. Just add a PU camper shell and you're ready to hit the road!!
Guy
"We're all bozos on the bus, so might as well sit back and enjoy the ride."
Wavy Gravy
Powered By MyBB, © 2002-2017 MyBB Group.
