  • 2 Vote(s) - 5 Average
Van Dimensions Sticky
#41
Anyone have dimensions for Toyota Sienna 2006-2011?
Sent from my HTC One_M8 using Tapatalk
#42
Nissan Cargo Van  NV2500 V6 High Roof
Wheelbase    146.1
Overall length    240.6
Overall width (without mirrors)    79.9
Overall width (with mirrors)    99.5
Overall width (with tow mirrors)    102.8
Overall height (Standard Roof)    83.9
Overall height (High Roof)    105.0
Track width (front)    68.7
Track width (rear)    68.9
Sliding side door width    41.7
Rear door opening width    59.8
Rear door opening height (Standard Roof)    49.8
Rear door opening height (High Roof)    71.5
Step-in height (front)    18.0
Step-in height (sliding side door)    19.4
Step-in height (rear)    19.8
Cargo area liftover height    28.5
Angle of approach (degrees)    17.5°
Angle of departure (degrees)    17.4°
Turning Diameter (ft.)    45.2
Interior Dimensions - Inches
Head Room (Standard Roof)    42.8
Head Room (High Roof)    63.6
Leg room    42.0
Hip room    60.6
Shoulder room    65.7
Cargo Dimensions - Inches
Cargo volume (cu.ft.) (Standard Roof)    234.1
Cargo volume (cu.ft.) (High Roof)    323.1
EPA interior passenger volume (cu. ft.) (Standard Roof)    68.3
 EPA interior passenger volume (cu. ft.) (High Roof)    101.5
 Total interior volume (cu. ft.) (Standard Roof)    299.7
 Total interior volume (cu. ft.) (High Roof)    420.5
Maximum cargo length    120.0
Maximum cargo length behind center console at vehicle center    121.9
Maximum cargo length without center console at vehicle center    150.4
Maximum cargo width    70.2
Cargo width at wheelhouse floor    54.3
Maximum cargo height (Standard Roof)    55.8
Maximum cargo height (High Roof)    76.9
 Capacities
Roof load capacity (lbs.) (Standard Roof)    500
 Roof load capacity (lbs.) (High Roof)     300
Seating capacity    2.0
Fuel tank (gals.)    28.0
Engine oil (qts.)    5.4 (V6)
Weights - Lbs
GVWR    9,100
 Weights - High Roof - Lbs
Curb Weight (lbs) - V6    6,079
Payload - Lbs
High Roof- V6    3,021
 Towing Capacity - Lbs
With tow hitch receiver (V6)    7,000
Smile
Nissi     Smile
Nissan NV2500 High Top
The following 2 users say Thank You to Nissi for this post:
frater secessus (01-01-2018), wistful vista (11-23-2017)
#43
Not know which year you wanted, but we have the 2006, so...
Specs for the 2006 Toyota Sienna
Dimensions
  • Front Head Room:   42.0 "
  • Front Leg Room:   42.9 "
  • Overall height:   68.9 "
  • Overall Length:   200.0 "
  • Overall Width:   77.4 "
  • Rear Head Room:   40.2 "
  • Rear Leg Room:   39.6 "
  • Wheelbase:   119.3 "
Other exact specs here:   https://www.autobytel.com/toyota/sienna/...fications/
Hope this helps
Smile
Nissi     Smile
The following 1 user says Thank You to Nissi for this post:
mobile_kuti (10-30-2017)
#44
Thanks Nissi!
#45
Welcome...
Smile
Nissi     Smile
#46
Does anyone have the inside measurements of an Astro van?  Specifically I am interested in the length from behind the seats to the rear doors and the width.
No hurry ... No worry
#47
Astro Van Inside Measurements
I found a Youtube channel (Traveling Troy) that gives the inside measurements of an Astro van in detail.  Here is a link to Troy's video:
Astro Van Measurements
and here are the details:
Measurements: Back door to top of Driver's seat - 86.5 inches Back door to base of Driver's seat - 93 inches Area between wheel wells - 51.5 inches Wall to Wall above wheel wells - 69 inches Floor to Ceiling - 50 inches Floor to Ceiling ribs - 48 inches Back door to wheel well - 17 inches Wheel well length - 32.5 inches Wheel well width - 7.5 inches Wheel well height - 10.5 inches Wheel well to Driver's side seat belt box - 39 inches Back door to Sliding door - 52.5 inches Wheel well to Ceiling ribs - 36 inches Sliding door length - 38 inches Depth of step - 5 inches Width of step - 7 inches Step length - 38 inches Base of Step to Ceiling rib - 51.5 inches Back door ceiling to front headliner - 81 inches
  Vans wider than 6 feet ? split from Van Dimensions Sticky Vagabound 2 1,197 08-25-2016, 07:38 AM
Last Post: accrete
