CO Detectors
RV CO detectors are cheap.
http://store.qginc.com/
Amazon sells that cheap detector and it gets terrible reviews, I wouldn't bet my life on it:
http://www.amazon.com/COSTAR-906002704-C...000FGECW6/
Bob
The following 1 user says Thank You to akrvbob for this post:
highdesertranger (12-27-2014)
(12-27-2014, 05:36 PM)akrvbob Wrote: Amazon sells that cheap detector and it gets terrible reviews, I wouldn't bet my life on it:
Bob
Reading the reviews it doesn't sound too good...
I'm leaning toward the Kidde, at least it is a well known name brand... whatever that's worth nowadays...
Andrew
[Image: RVNsvc1966.jpg]
A few things I've found out about CO detectors:
1. All CO detectors have a limited lifespan, when first introduced they were a year or two, now they're usually about 5-6 years, possibly a bit more.
2. A detector with a digital readout can tell you how much CO is in the air even though it's below the detector's alarm point -- sounds like something worth knowing.
3. Putting one in a van or rv means that the mounting location is not going to meet the usual recommendations, at least not in my Astro (read small).
Andrew
Does kidde make a rv unit? 3 and a half stars is not a bad review on amazon.
(12-28-2014, 12:06 PM)ccbreder Wrote: Does kidde make a rv unit? 3 and a half stars is not a bad review on amazon.
Not that I'm aware of, but I will monitor it closely and report on its performance...
Andrew
They have a lower operating temperature and humidity limits. Parked in the sun could kill them.
(12-28-2014, 12:37 PM)ccbreder Wrote: They have a lower operating temperature and humidity limits. Parked in the sun could kill them.
Not to mention the fact that vehicles can shake things up quite a bit, depending on the road. A CO detector designed for a house may not hold up to that, could maybe fail without it being obvious that it's no longer working.
Regards
Regards
I thought of stuff like that and decided to take a chance. Since the one I am getting has the lcd display it will be very apparent if it stops working, as long as I occasionally look at it that is...
Andrew
Mine is a Safe T Alert specifically for RVs.
 [Image: Updated%20sig%20pic.jpg]
The following 1 user says Thank You to mockturtle for this post:
Kathleen (12-08-2017)
