Wire sizes and Fusing
(05-29-2015, 06:17 PM)akrvbob Wrote: So what wire sizes do you use for typical vandwelling installations?
Being a lazy bastard, my theory is to just buy 12 Gauge Automotive Zip Cord and use it everywhere.  Using zip cord is easier than running separate power and ground wires.  The red and black makes it simple to keep positive and negative straight.  I can color code my runs with short pieces of colored heat shrink on each end.  It's easier to keep a lot of one size around than to try to stock different sizes of wires.  And I pretty much don't have to worry about voltage drop on any realistic run length.  It is, of course, massive overkill on things like LED lights, which would probably be happy with 18 gauge.  But as Master Redneck Engineer, I LIKE massive overkill, as long as it doesn't add a lot of unnecessary weight.
Regards
Regards
(05-31-2015, 10:42 AM)Optimistic Paranoid Wrote: Being a lazy bastard, my theory is to just buy 12 Gauge Automotive Zip Cord and use it everywhere.  Using zip cord is easier than running separate power and ground wires.  The red and black makes it simple to keep positive and negative straight.  I can color code my runs with short pieces of colored heat shrink on each end.  It's easier to keep a lot of one size around than to try to stock different sizes of wires.  And I pretty much don't have to worry about voltage drop on any realistic run length.  It is, of course, massive overkill on things like LED lights, which would probably be happy with 18 gauge.  But as Master Redneck Engineer, I LIKE massive overkill, as long as it doesn't add a lot of unnecessary weight.
Regards
It's also an economical bastard thing - buying 3 or 4 different sizes of wires gets expensive. Other than lumber and maybe screws, I'll have enough left overs to do another van by the time I'm finished... Rolleyes
Thanks John, you just answered one of my questions - 12 gauge zip cord it is for all the 12 v in the van.
That is, if it's the right wire for the Whynter fridge wiring - is it?
(05-31-2015, 11:27 AM)Almost There Wrote: That is, if it's the right wire for the Whynter fridge wiring - is it?
It will safely carry 20 amps.  I don't know what the Whynter needs off hand, but it's hard to believe it would be more than 20 amps.
Regards
Regards
Are you saying you use AWG12 for ALL the wires? Even the wires going from Array to CC, to Battery, to inverter?
Please make sure the 12 awg zip cord is actually copper, and not aluminum or CCA, copper clad aluminum.
The AWG sizes for fridges, well throw out ampacity charts and wire them fat and short as convenient.
Danfoss/Secop wants their compressor controllers wires directly to battery terminals, fised at battery terminals, and the wire thickness they recommend is MUCH MUCh thicker than what ampacity chart say is adequate for the amperage their compressors can pull.
When Danfoss compressors suffer too much voltage drop, the compressor will not kick on, but the condenser fan will. Since the fan is usually as loud as the compressor in most stock danfoss/secop compressors, the owner believes the fridge is operating properly, when it is not.
I assume the Whytner's compressor is as susceptible to voltage drop as actual Danfoss Secop compressors. The Sawafuji compressors do not have as high a starting surge and are more tolerant of thinner copper to them.
So read this PDF from Danfoss, and make sure the fridge is well wired with minimal connections, and if reliability is important, get that Effing Ciggy plug and ita 18 awg cord out of the circuit.
Notice that for 12 awg is only acceptable for 8 feet of wire total, 4 feet to and 4 feet from:
http://www.ra.danfoss.com/TechnicalInfo/...00m602.pdf
99% of reported issues with 12v compressor fridges is either the ciggy plug itself, or the poor stock wiring leading to the Ciggy plug.
Wire it thick and get that Ciggy plug out of any install which is to be more permanent. I installed a 45 amp anderson powerpole on the original powercord of my Friends ARB fridge. He can still use it on a ciggy plug, but it performs better when the powerpole is plugged into 10AWG that goes only 12 inches or so to the fuse block.
Throw out ampacity charts where battery charging or running a fridge is concerned. Huge performance/reliability increases are possible with 'oversized' wiring.
Voltage drop is the Nemesis of 12vDC systems, and thicker copper is the prescription for a cure.
Inverters need thick and short copper to prevent that pesky low voltage alarm from sounding. I use 8awg for 16 inches one way on a 400 watt inverter.
The following 2 users say Thank You to SternWake for this post:
dr_nelson (07-03-2017), cortttt (06-16-2016)
(11-15-2015, 03:19 PM)FALCON Wrote: Are you saying you use AWG12 for ALL the wires? Even the wires going from Array to CC, to Battery, to inverter?
No, those things need much fatter wires.  I'm saying just use 12 gauge for stuff like lights, fans, roof vents, etc.  You could get by with lighter wires on much of that stuff, especially LED lights.  But I think it's simpler to just have one size wire and not have to concern myself with voltage drop calculations.  Especially for utility circuits where you aren't sure what you might wind up plugging in to it down the road.
Regards
Regards
The following 2 users say Thank You to Optimistic Paranoid for this post:
dusty98 (11-15-2015), FALCON (11-15-2015)
(05-29-2015, 12:37 PM)GotSmart   Aluminum and copper have different coefficients of expansion and joints between them will - over time - work loose. T hat goes for connections of aluminum wire to switches and plugs.  My condo was wired with aluminum 30 years ago and I had trouble with flickering lights and things plugged into wall plugs not working right.  i finally went through the house and put a short pig-tail ( 4 to 6 inches) of copper wire between the aluminum wire and the switch or plug.  At the connection between the aluminum wire and the copper pigtail i used a "wire cap" ( may not be the right name - one of those little plastic caps that you screw onto where the two wires are wrapped around each other) .   I packed the cap with some anti- oxygenation goop that keeps the oxygen from getting into the  joint.  Haven\t had any trouble in years. Wrote: Also the type of wire also makes a difference.  Aluminum wire is inferior to copper wire, and has a tendency to compress at the point where it is clamped.  When I had my house, I had to tighten the wires going to the AC system from the fuse box twice a year to keep it operating properly.
Spend the extra money and buy copper.
Tulsatraveler
The amp rating for wire has more to do with heat than efficiency. larger wire will give less voltage drop. I like to go one wire size over. 12 gauge for a 15 amp fused circuit is good for me.
''"Notice that for 12 awg is only acceptable for 8 feet of wire total, 4 feet to and 4 feet from:
http://www.ra.danfoss.com/TechnicalInfo/...00m602.pdf ""
The figure 2 chart seems to be incorrect, notice it has two lines for 12 awg. The first line must be 14 awg. The asteric (*) indicates the foot measurements are from the battery to the compressor. Not round trip.
I'm not sure if this is the best thread for this, but I am hooking 2 12volt 160ah batteries in parallel and used a switch to starter battery cable I found at auto zone. It is 4 GA and 19" long. Is this substantial enough? My concern is that when I hooked a battery charger to the setup after putting them in parallel (charger was on one battery's + and the other battery's -) I heard gurgling sounds from the batteries. Is this normal? Maybe I didn't have the cables tightened enough? I just don't want to ruin my 2 new AGM batteries/have them blow up and ruin other stuff.
if journeying with others, there are many plans to coordinate;
if journeying alone, you can leave right now.
  Fuses and Breakers and Wire Sizes for Solar System Laughing Richard 18 12,006 05-27-2013, 12:15 PM
Last Post: wrcsixeight
  wire sizes for solar cedric 11 3,964 11-19-2012, 11:59 AM
Last Post: cedric
