How To Unsubscribe (stop notifications)
#1
Information
How to stop email notifications:
1)  Log into the forums
2)  Go into your "User CP" (control panel, at upper right) at http://www.cheaprvliving.com/forums/usercp.php
3)  Go into "Subscribed Threads" (lower left column) at http://www.cheaprvliving.com/forums/user...scriptions
4)  Delete all thread subscriptions (check mark each on right, then "Delete subscriptions" from drop-down menu at bottom right, press the "Go" button)
5)  Go into "Forum Subscriptions" (lower left column) at http://www.cheaprvliving.com/forums/user...scriptions
6)  Delete all forum subscriptions (check mark each on the right, then "Delete subsciptions" from drop-down menu at bottom right, press the "Go" button)
7)  Go into "Edit Options" (middle left column after gear icon) at http://www.cheaprvliving.com/forums/user...on=options
8)  Find the drop-down menu under "Default Thread Subscription Mode" (in the section titled "Messaging and Notification")
9)  Set drop-down menu to "Do not subscribe"
10) To remove email notifications of PMs (private messages), uncheck the box to the left of "Notify me by email when I receive a new Private Message."
11) Click on the "Update Options" button at the bottom.
#2
Lately, I've seen several members post questions about how to stop notification emails. So, I thought I'd "bump" these instructions to the top in case you are also wondering how to turn your automatic subscriptions off (or on).
