Unlimited Sprint LTE for $14 a month.
I have the franklin 850 also. It's just that you might have overcharged the battery and it will not do a full charge cycle like original. Still may work. It's a thing with lithium batteries. That some charge circuits are poorly designed and they keep pushing current even after the battery is fully charged.
In other news the hotspot went down to 500 Kbps yesterday Sunday at 6pm. Likely a heavy traffic time for sprint 4g data traffic on the cell towers. But did some PRL updating and VPN PASSTHROUGH setting got the hotspot back to at least 1mbps speed. That is at least functional for video streaming. This morning at 3:30 to 4am I am getting 10 Mbps speed. So I know it's traffic on the towers.
So now am debating sticking with my land line which always gets 10mbps at $60 a month. Or this 4GCommunity hotspot and doing $20 a month. And just doing some self throttling and internet usage control. Don't need to be online constantly.
I got the more expensive ZTE pocket WiFi hotspot, since the R850 doesn't seem to support USB tethering. At my house the speeds blow my at&t hotspot out of the water, http://beta.speedtest.net/result/6480418882 if I put it in just the right spot. I loaded openwrt on my home router to get 4 ethernet ports and more wifi range out of it. Like my AT&T hotspot, using USB tethering instead of WiFi seems to improve the speeds if there's strong signal and low traffic on the tower.
(07-24-2017, 02:44 AM)Lost in the world Wrote: I got the more expensive ZTE pocket WiFi hotspot, since the R850 doesn't seem to support USB tethering. At my house the speeds blow my at&t hotspot out of the water, http://beta.speedtest.net/result/6480418882 if I put it in just the right spot. I loaded openwrt on my home router to get 4 ethernet ports and more wifi range out of it. Like my AT&T hotspot, using USB tethering instead of WiFi seems to improve the speeds if there's strong signal and low traffic on the tower.
I see the R850 does support tethering via a HIDDEN menu. But the discussion says it's not very fast. Have not read anything from anyone who is continuing to use USB tethering on R850. You can buy a TRAVEL ROUTER to connect something that is wired Ethernet to a wifi signal.
Also testing tuning on and off certain bands in the HIDDEN menu. They worked but did not help with speed. This morning at 7am got 6mbps or as low as 3mpbs. Still very functional.
Turned off my home wired AT&T router and will use the 4GCOMMUNITY router now instead for a few days exclusive while in my trail period.
Just for what it's worth report. I've been using 4gCommunity.org for about 6 months now. I happen to live in an area where Sprint gives me the best signal even though it is only 2 bars. 4gCommunity has been my main supplier of data. I've tested the major suppliers except T-Mobile and sprint works best for me.
I now have Mobley for when I travel and I ordered Verizon 3g also. Should be here later this week. Not a bad lineup for $39.00 per month.
Sprint can actually be really fast. A single strong signal on band 41 can easily produce 50+ Mbps. I would have no issues recommending them if I knew a person was in a good city for Sprint. Add in that their 3G foot print is much larger than T-Mobile and is usable in a lot of areas people do not think about and that their roaming partner is Verizon, it becomes a lot more viable for the cost.
Only question I have is...how is sprint in BLM land?
Since I plan to spend close to no time anywhere near a city...strong signal out in Timbuktu is what counts for me.
The following 1 user says Thank You to RoamingKat for this post:
galladanb (09-29-2017)
(03-02-2017, 12:34 AM)jimindenver Wrote: I'm sorry I missed this but yes I have used it a number of times out here on the road. When it gets the best signal it is so much faster than the rest it isn't even a contest as it can pull down twice as fast as Tmo, four time as fast as cricket and tens time as fast as Verizon 3G. Two weeks ago in the casino parking lot it felt like I was on high speed cable as nothing even buffered at all. It just started playing.
Jimindenver, I just found this post and I really need a lower cost internet source. Are you still using this service and is it still performing well?. Thanks Jeff B.
Kat
The answer to that depends on just where you are. I have had areas where each carrier sucks or is none existent. I have had Sprint work wonderful between Cottonwood and Sedona, both locations in Flagstaff, and even out on Gooseberry mesa in Utah. All of those were pretty far from a town. There are times it gets no signal at all but I have seen that on all of the carriers. The best low cost internet option right now is the Mobley on AT&T unlimited for $20 a month. It is rare that I have Verizon but no AT&T. The 3G Verizon at $5 a month is next but not high speed.
(07-24-2017, 04:13 PM)Jbent1@hotmail.com Wrote: Jimindenver, I just found this post and I really need a lower cost internet source. Are you still using this service and is it still performing well?. Thanks Jeff B.
Jeff
I still use this along with my other hotspots. I turn them all on when I reach a spot and first see which gets a signal, followed by which gets the fastest signal. I know that when my 4Gcommunity Sprint hotspot sees 3 to 4 bars of signal that streaming with it will not be a issue. So if you are in a area with a good Sprint signal, I say go for it. I will be happily paying for another years service when it comes due.
(07-24-2017, 03:34 PM)RoamingKat Wrote: Only question I have is...how is sprint in BLM land?
Sprint is URBAN. Don't expect rural functionality. There are lots of heat map coverage map tools to tell you if you might get a signal. Choose your camp spot wisely.
  Verizon 3G MiFi Unlimited $5 a month Jeanne Temple 7 170 14 minutes ago
Last Post: Jeanne Temple
  Unlimited Verizon 3G $5 a month jimindenver 927 129,489 01-14-2018, 04:44 PM
Last Post: Eaglefly
  Unlimited AT&T $20 a month jimindenver 238 16,945 12-27-2017, 07:58 PM
