Diesel Truck
(11-02-2016, 04:04 PM)Baloo Wrote: I second that notion! Mechanical diesels are stupid simple and easy to diagnose and repair. Almost all issues can be attributed to bad fuel, bad fuel filter or water in fuel.
I third that notion.
If you're a mechanically inclined person then the old diesels will be cake compared to the new ones.
The only thing I would add is that in a diesel engine, your vacuum pump is actually important. In gas engines it's acceptable to brush a vacuum pump issue to the sidelines, but in a diesel engine this can negatively impact your transmission. So long story short, if you've got a vacuum pump issue on a diesel, don't make the same mistake I made by putting it on the sidelines. Be knowledgable of your engine's abnormalities compared to other vehicles you've driven so you know when something's serious.
"A man convinced against his will
  Is of the same opinion still..."
ha ha I don't have no stinkin vacuum pump. don't need one, I have nothing that requires vacuum. highdesertranger
(11-04-2016, 07:58 AM)highdesertranger Wrote: ha ha I don't have no stinkin vacuum pump. don't need one, I have nothing that requires vacuum. highdesertranger
Yeah, vacuum pump! pffft'd my brakes are electric over hydraulic. The vacuum pump in the Ambo is my shopvac!
In all seriousness, my 7.3 had a vacuum pump and I never had an issue with it.
1994 International Road Rescue Ambulance, 2003 Jeep Wrangler
I have been happy with my Diesel Dually 4X4 Silverado 3500. Yes there is a small learning curve on diesels but forums are a great help. As for buying a good one , mine is a 2006 LLY Duramax, well built with a tuner and I pull and have since 2008, 13,500 daily so my vote is duramax, but the cost is high, I would not sell mine for 20K.
BildrRick
I don't know whether you bought a new truck or not but I can vouch for the 7.3L Powerstoke that Ford put in their trucks back in the late '90s and early '00s. My fifth wheel is about the same weight dry as the one you are being given and is easily pulled with my 2000 F-250 with manual transmission. It is mostly bombproof and easy to fix and maintain and the mileage really isn't too bad, better when hauling than my old gas 2500.
To give you an idea I traded a 2001 Dodge with an auto tranny for this truck and the asking price was $10K with 140,000 miles on it...so plenty of life left. Six years later you could find a great truck for the same price or less which sounds well within your budget.
Big Blue also handles some seriously tough terrain and back roads and has hauled loaded horse trailers into some pretty remote back country. A great all around truck and a little easier to find than the same generation Dodge Cummins. You'd have to pay me a ridiculous amount of money to sell it, and even then it might be up for debate since I love that thing
2007 Keystone Springdale
2000 F-250 7.3L
Cody & Kye, border collie extraordinaires
Find us: www.nomadicpawprints.wordpress.com
For me a used diesel that is out of warranty is a big gamble. It could run forever, but it might cost a fortune to do it.
The world is not perfect, and neither am I. Get over it already.
I've had multiple diesel powered vehicles and equipment in my life. Nothing runs like an older naturally aspirated diesel. Unfortunately, once environmental equipment was added, life spans began to shorten. With the addition of turbo chargers for pickup truck applications, durability came into question once again. The old Cummins and Detroit diesel engines would run forever. That simply is not the case now without substantial repair and maintenance costs....
On the Ground Travel Channel - Jayco Jay Flight 23RB - Subaru Outback
Like us on facebook http://alturl.com/4wzuy
For what its worth.....2005 Dodge Cummings 5.9...now has 320k miles.  the first 295k was done pulling a 4 car trailer.
Other than belts and breaks and a water pump no issues. Injectors were changed at 298K ....not because of a problem but as a preventative measure ($2500) Love my Cummings, there is nothing it cant pull.
Would a 97 Dodge Cummins Diesel be considered the old mechanical diesels?
the break year for the Cummins was 1998. before 98 they were called 6BT after 98 they were called ISB 5.9. you want the 6BT, they are mechanical. highdesertranger
