  • 1 Vote(s) - 4 Average
simple/solo boondocking: Promaster 159 high roof
In other news, I ordered wiring for the build.  Amazon was cheaper than Home Depot so I mail ordered it.   I need to get the wiring pulled so I can start insulation.
  • 10/2 for heavier loads (fridge, maxxfan) and for bringing 12v power to the other side of the van (for two circuits:  normal and opportunity load)
  • 16/2 for things like usb outlets, LED lighting, etc.
  • 14/3 for running shore power to the far side of the van where I will have one outlet. To balance out weight I have the converter+batteries on one side and kitchen+water on the other (where the outlet will be) so I'd have to run 110v across the barn either way.
  • various bus bars, grounding bars, fuse block
I need a breaker box and 15A breaker for shore power but I don't know much about those yet.  I assume there are Very Small breaker boxes available for 1 or 2 breakers, and I assume there are different form factors of breakers so they don't fit every box.  Just started that reading.
frater/jason @ Quartzsite
AbuelaLoca (06-07-2017)
(06-07-2017, 09:44 AM)caretaker Wrote: How do you plan to anchor shelves or whatnot one would anchor to the floor?
Current thinking is 80/20 framed cabinets bolted to the wall studs (?).   The mat is scored to make the Drings accessible, if needed to give backup to heavier stuff like water, battery boxes, etc.  The battery box will be placed against the forward step-up to ward off deceleration events.
Wonderful thread, frater! Love, love, love that flooring! I remember it mentioned in another thread somewhere... would you mind telling the cost?
PS... I missed this thread because I thought it was about boondocking LOL
'93 Club Wagon (Juanita) & AbuelaLoca (Belinda)
All aboard! Ha ha ha ha ha ha haaaa!
Ay, Ay, Ay, Ay, Ay, Ay, Ay
I just looked them up and they don't make a rug for my van! Bummer!!!
(06-07-2017, 02:27 PM)frater secessus Wrote: In other news, I ordered wiring for the build.  Amazon was cheaper than Home Depot so I mail ordered it.
Links to your cable sources?
(06-07-2017, 02:27 PM)frater secessus Wrote: for two circuits:  normal and opportunity load
Wow, who runs that wiki? I've been looking for a place online to organize a public knowledge base, and DokuWiki is the bee's knees, the markdown it uses is very compatible with my tools.
And that concept is great, what sort of dump loads were you thinking?
Related to that is an idea I have about staging the charging of multiple power stores in priority order. There are Sterling/ProMariner VSR units ("Pro Split R") that do that for up to four banks, using any/multiple charge sources. I reckon they can be adapted to use with Load management as well as charging. Of course laptops and other gadgets with their own batteries and those portapacks fall in between.
Are you planning on a charging buss separated from Loads?
(06-07-2017, 02:32 PM)frater secessus Wrote: Current thinking is 80/20 framed cabinets bolted to the wall studs (?).   The mat is scored to make the Drings accessible, if needed to give backup to heavier stuff like water, battery boxes, etc.  The battery box will be placed against the forward step-up to ward off deceleration events.
I'd look into E-track strips run along the walls. Very strong and versatile tiedown systems.
The following 1 user says Thank You to Bud Smiley for this post:
frater secessus (06-07-2017)
(06-07-2017, 04:01 PM)AbuelaLoca Wrote: Wonderful thread, frater! Love, love, love that flooring! I remember it mentioned in another thread somewhere... would you mind telling the cost?
$230, I think.  Pricey, but I didn't have to buy other materials or cut anything.  I am a cheapskate and am 100% satisfied with the spend.
Are you sure there's not one for your van?  isn't the club wagon an E-150?  I ran the selector and I think they have them for 138" and 138" extended.
The VanTred 138" appears to be PART # VTRF92 (amazon)
The VanRug 138" appears to be PART # VRF92 (amazon)
but don't trust my googling!
AbuelaLoca (06-08-2017)
(06-07-2017, 04:38 PM)John61CT Wrote: Links to your cable sources?
I searched the forum for info on wire choice + SternWake.  :-)  I found threads with  SternWake saying he uses landscape wire, a duplex low voltage wire.  I'd never heard of it but it sounded worth reading about.
I dredged up the link for the 10/2;  it's this stuff from 1000bulbs, a seller some of the buyers mentioned for good product.  16/2 here.
The 14/3 is normal house stuff, in this case 25' from Temco Industrial.
I looked for stranded copper core wire with good reviews and good price.  I hope I didn't miss anything.
(06-07-2017, 04:38 PM)John61CT Wrote: Wow, who runs that wiki? I've been looking for a place online to organize a public knowledge base, and DokuWiki is the bee's knees, the markdown it uses is very compatible with my tools.
I do.  It's basically where I try organize stuff I learn from you guys, YT, and elsewhere. It's kind of a mess because I am learning so much.  I was doing it for myself but sometimes found it easier to point to a URL there instead of typing stuff out again.  Plus if I document it correctly there are source notes so folks can follow up to see if I am mischaracterizing the information.
If you are interested I'll make you a user/pass and turn you loose on it.
(06-07-2017, 04:38 PM)John61CT Wrote: And that concept is great, what sort of dump loads were you thinking?
There are a few reasons for wanting to do it:
  1. experiment in hopes we can refine ways to help people with minimal solar get the most out of it
  2. charge phones/tablets/laptop when we have surplus power
  3. to donate spare power when I am topped off.  I am installing a USB + ciggy socket near the sliding door so folks can use the opportunity circuit when visiting.  It will be the only ciggy socket I put in the van, placed there for the convenience of others since I figure folks low on power don't overlap much with powerpoles crowd.
  4. donate mifi bandwidth through a repeater powered on the opportunity circuit.  If I'm low on power there is automagically no free wifi  :-)
  5. and the odd one:  heat (or just warm) water
Electric heat is notoriously expensive for water heating but by definition here the power on the opportunity circuit is free.
(06-07-2017, 04:38 PM)John61CT Wrote: Related to that is an idea I have about staging the charging of multiple power stores in priority order. There are Sterling/ProMariner VSR units ("Pro Split R") that do that for up to four banks, using any/multiple charge sources. I reckon they can be adapted to use with Load management as well as charging. Of course laptops and other gadgets with their own batteries and those portapacks fall in between.
That sounds great and quite beyond my abilities.  I am working with cruder hardware and brainware, I fear.  :-)
(06-07-2017, 04:38 PM)John61CT Wrote: Are you planning on a charging buss separated from Loads?
I don't think I know what that means, so I'm saying "no" for now.  :-)
In my case there are two charge controllers, one for the panels and another one in a  poor man's converter.  The Load output on each runs to its relay which activates that circuit as long as one is above LVD.  LVD on the the solar CC will be set at normal LVD (50% DoD) while the LVD on the converter controller will be set at Vfloat.
(06-07-2017, 06:27 PM)frater secessus Wrote: That sounds great and quite beyond my abilities.  I am working with cruder hardware and brainware, I fear.  :-)
These two quotes are what fascinate me about this forum, there is a breadth of knowledge that is astounding.  I have no idea what you are talking about in this post, you far surpass my understanding of all things electrical... level up and John confuses you... level up again and someone here is an actual electrician.  And everyone is willing to share what they know.  Very cool beans.
“If the words you spoke appeared on your skin, would you still be beautiful?”
~ Auliq Ice
The following 3 users say Thank You to Queen for this post:
GeorgiePorgie (12-30-2017), frater secessus (12-04-2017), AbuelaLoca (06-08-2017)
(06-07-2017, 06:27 PM)frater secessus Wrote: I looked for stranded copper core wire with good reviews and good price.  I hope I didn't miss anything.
Maybe just some overkill, for mobile DC I'm sticking to well recommended marine rated, but boy that hurts! when you get to the heavy stuff. . .
(06-07-2017, 06:27 PM)frater secessus Wrote: I don't think I know what that means, so I'm saying "no" for now.  :-)
From my research into DIY BMS design, LiFePO4 requires isolating the bank due to overvoltage, too high or low SoC or temperature, or based on current.
I plan to have a setup where I can switch bank chemistries without changing the rest.
By routing all charge sources through one buss, switched independently from the load buss, you can protect the bank from e.g. charging below freezing by opening the charge cutoff, while still allowing loads to be fed.
Or isolating loads when SoC drops too low, but obviously you want to allow re-charging when a source becomes available.
Doesn't have to add much cost, maybe one buss and some wiring, as long as you plan it out beforehand.
