  • 2 Vote(s) - 3.5 Average
The Fat Van rides again
Be a lunch mobile on the side.  Tongue
The following 1 user says Thank You to CautionToTheWind for this post:
FibroWarrior (10-05-2017)
touch n seal 110bf 2 parts closed cell spray foam
before
[Image: WXlUlNM.jpg]
[Image: fAZJabs.jpg]
[Image: ARHHiTf.jpg]
just after
[Image: D56GV4N.jpg]
[Image: 3kmy9WO.jpg]
after some putty knife and fine tooth wood saw
[Image: 8ywrHbL.jpg]
[Image: gjaOzhp.jpg]
worked out great and stiffened the walls up too
dont get to fancy,see the last pic upper right,i tried to do around the wire harness and it expanded,now i have to go in and cut some out
got myself dressed up like a mummy,drench in sweat,didnt get a drop of overspray on me
The following 4 users say Thank You to Gary68 for this post:
jimindenver (07-14-2017), AbuelaLoca (07-09-2017), rvpopeye (07-09-2017), Ballenxj (07-09-2017)
of course they screwed me with the windows,so they had 5/8" plywood and the 1/8" paneling so when i replaced the rot i used 3/4" wood and was going to place 1/8 material on the rest of the plywood to get back to specs but it turns out they were 1/8 short and made it up with 2 layers of 1/8" thick butyl tape
so i ended up using 1/4" plywood(the old water tank cover)on the existing plywood and 1/8" on the wood to get to about 1/16" larger then the window frame
anyway widows in good butyl squish all around
[Image: zL95wBN.jpg]
bonus feature of giant windows,screens slide open
[Image: WbhdrOA.jpg]
the butyl tape to buy
http://shop.marinehowto.com/products/bed-it-tape
shade tree hack tip-by the time i got to cutting off the extra butyl it had been in direct sun and was the consistency of bubblegum so i hit it with the water hose and it turned back rubbery and was much easier to peel off and work with
keep the butyl coolish
The following 2 users say Thank You to Gary68 for this post:
AbuelaLoca (07-18-2017), highdesertranger (07-14-2017)
bonus pic
patiently waiting
[Image: IHm5d3V.jpg]
the one next to it is a little different ,bloomed earlier and has been devoured
The following 1 user says Thank You to Gary68 for this post:
am i going to seal the plywood floor with something or not? thoughts?
^^^ That depends on what flooring you're planning on putting down over top of it.
If you're putting wood laminate or carpet down, I'd seal it.
If you're putting vinyl or vinyl laminate down, wouldn't worry about it.
Or you can seal it well, paint it with outdoor deck paint, put throw rugs down and call it good. You could even get decorative with the floor paint if you wanted to.
Gary68 (07-14-2017)
(07-14-2017, 03:34 PM)Almost There Wrote: . You could even get decorative with the floor paint if you wanted to.
Maybe paint some buttercups.
What do ya got laying around?
Stay Tuned
popeye
paint it with deck paint? highdesertranger
It's a high traffic area HDR - if you're going to paint it with anything you want something that is going to stand up to the wear and tear of being walked on, things dropped on it, water/coffee etc spilled on it.
Regular inside house paint ain't gonna cut it. Deck Paint is meant to take a beating!
Gary68 (07-14-2017)
