How long tween trips for Thetford units...
So, what I'm asking is, how long can one leave the deodorant in the thetford between trips?
We are not going on trips all the time, and I was wondering about dumping the loo after each trip, even if it got used very little....
Or not at all, for instance.
That chemistry seems kinda expensive to just dump....
I mean if we filled the bottom portion as intended by design, that's one thing, but to have hardly used it, is another.....
Does that make sense, or am I just overthinking this whole messy biz?? Lol!!!
Thx, Dan'l
Big plans, Mini budget!!!
I thought you were having trouble keeping a Ford from being stolen...
1993 Ford E150 conversion
Me, too!
If you leave it for a period of time, the liquid will evaporate away and that leaves you with, uhm, a chunk of yuk that would be problematic to remove.   As for the chemicals, I use 'Happy Camper' odorless treatment, added just before a trip and dump after each trip regardless of amount of use.
https://www.amazon.com/Happy-Campers-Org...B005XEFADU
The following 1 user says Thank You to dexstrom for this post:
tav-2020 (11-13-2017)
Oops, I just now saw the tag line, sorry. My typo skills are off da chart!
I don't have way to fix it now.... I meant for it to say "thetford". Yikes!
I kinda figured it would be a post trip de-briefing kinda thing...
Just thought I'd ask, lol!!!
Thx, Dan'l
Hey Dex....
That says one scoop per forty gallons...
My tank is only 2.5 gallons... It's just a little ports party.
How much would I use for that?
Thx, Dan'l
Fixed the main one for you.
The following 1 user says Thank You to Nomadventurer for this post:
galladanb (09-09-2017)
Thank you, kind sir!!! You roc!
Thx, Dan'l
galladanb, since 2.5 gallons is appox. 6% of 40 gallons. use 6% of a scoop. to get precise, weigh a full scoop then do the math fill the scoop up with 6% of the weight of a full scoop. then mark your scoop. highdesertranger
galladanb (09-10-2017), dexstrom (09-09-2017)
HDR, yur da man! Thx!
Math, yuk! But of course that's the answer!
That bucket will last a long home, lol!!!
Thx, Dan'l
The following 1 user says Thank You to galladanb for this post:
highdesertranger (09-10-2017)
