Tires, your money or your life. FYI Guidelines
Tire Guidelines
 Tires are very important for safety and reliability on the road. Your life and vehicle depend upon them. Good decisions avoid/minimize problems down the road, optimize your expenses and give safe, durable operation.
1. Get the best tire you can afford. Driver door jamb usually has the proper size and inflation.
2. Research tires for comparison and rating. Tire Rack, Consumer Reports, Prius owners forum report on fuel saving tires, etc... Compare price, performance, durability.
3. Research tires for best price online and in store before you need them to find a sale or deal. Sometimes can get a deal on nearly new tires on Craigslist from those who upgrade rims and tires " take offs". Walmart.com also can find deals.
4. Safety, start looking for tires before you need them. Said that 90% of all flats occur in the last 10% of tread. Won't find a deal when your stuck and will cost more. Plus avoid the hassle and potential danger/ damages of a flat or blowout. Procrastination here will cost you.
5. Check spare for condition and air pressure occasionally. Like, NOW.
6. Check air pressure frequently for maximum mpg and lifespan. Once a week, month.
7. Rubber hardens, weakens and dries out as it gets older (~5yrs+). Giving poorer braking, handling and more potential for flats and blowouts which is dangerous. Acceptable if driving local and slow. Could be hazardous for high speed, distance travel. General rule, replace if more than 5yrs old.
8. Tire sidewall info. Date of manufacture (4 digit code = week/year made. Get less than 2 yrs old, 1 or newer better), treadwear rating ( <500 lower mileage, +700 high mileage), speed rating ( higher means better made, safer), traction and temperature rating (A is best). See pics.
9. Carry can of sealant, plugs and patches, small compressor for on the road repairs.
10. You can drive on a flat if you have to, but not fast or far. Few miles, slowly at most. This will kill the tire, possibly damage the rim so only if you must.
11. Road hazard warranty worthwhile, depending on cost and if with national store chain.
12. AAA or other membership for bigger rigs can be a good thing. Cheap insurance and support.
As BTO sings,  Let it roll, roll on down the highway. Roll, roll, roll...
Would be great for everyone if someone could add info specific to larger rigs such as trucks, class C & A tire specfics.
https://youtu.be/XDl8ZPm3GrU
The following 1 user says Thank You to Minivanmotoman for this post:
deadwood (10-18-2017)
You might want to add some of the best ways of checking to make sure that you have the tires properly inflated for the weight you're carrying. What's printed on the door only applies to the OEM tires and what the tire sales people want you to inflate the tires to is usually tending to be towards comfort and high tire wear rather than longevity and safety.
Minivanmotoman (10-19-2017)
I've seen a lot of full size vehicles running tires which aren't E rated 10 plys ... THAT scares me.
And ... If you don't know what that means ... You need to educate yourself so you get the right tires for your rig.
The following 1 user says Thank You to Gideon33w for this post:
highdesertranger (10-18-2017)
yeah like Gideon says "E" rating for heavier vehicles. IMO a 3/4 ton or above needs a "E" rated tire. off road driving you need an "E" rating. highdesertranger
Minivanmotoman (10-19-2017), Gideon33w (10-18-2017)
I'd say that E rated tires are needed for almost all vandwellers given the weight we haul constantly.
Certainly better safe than sorry as far as tires. Less sidewall flex improves handling too.
yeah, i bought my wife "best we can afford" tires at costco for around $750 and she gets a sidewall puncture in 6 months. I give up. Granted they give you "tread credit" but still...sour taste in my mouth. Mind you we had another side puncture before that 2 years ago. both 60k miles rated tires (michelins, bridgestones), now completely useless.
Also, I forgot to add that I've read many complaints about costco tire road hazard warranty in 2017. some just flat out not honoring. I haven't gone to replace the damaged tire yet. Going this weekend. YMMV. We might not go costco next time around if they don't honor it.
Veteran's benefits:https://www.benefits.va.gov/benefits/
Apply: http://www.benefits.va.gov/BENEFITS/Applying.asp
PM me
Veterans Crisis Line 1-800-273-8255
"Also, I forgot to add that I've read many complaints about costco tire road hazard warranty in 2017"
interesting I have used Costco tire warranty many times never had any questions asked. yes the road hazard is pro rated but they all are. I remember once I had to pay .60 cents for a new tire. unfortunately my size of BFGoodrich are very hard to get so I switched to Goodyear Wrangler's and get them at Walmart. I haven't tried their road hazard yet. highdesertranger
Load range E? Why would you tell people that, arbitrarily?
There's load / pressure charts to determine inflation pressure, not a recommendation on a forum- vehicle / load sight unseen.
You might also note PSI / load rating stamped in rim may be below that of a 10 ply.
Not to sound like an old crow, but that's a bit irresponsible
You can repair sidewall injuries, my job at a truck tire shop was doing section repairs when I was young
Did thousands of sidewall repairs on all kinds of tires- Germans even make speed rated patches.
The following 2 users say Thank You to UptownSport for this post:
Minivanmotoman (10-19-2017), Weight (10-19-2017)
why do I recommend "E" rated tires for 3/4 ton and above, and for off road driving? experience that's why.
of course you need a rim to handle the load but we were not talking rims we are talking tires.
frankly I wouldn't want to drive the high desert back roads without "E" rated tires. highdesertranger
I've been preaching this to all my kids since they started to drive. You get the best tires you can for your car. It might just save your life. This is not the place to cheap out and try and save some money. Plenty of other places to do that.
I just put a set of all terrain BFG KO's on my van. I have a transit and there are not a lot of tires that fit the stock rim. But thankfully BFG makes a great all terrain and it is E rated and matches the factory specs very closely. I agree with HDR. If you are loading it up then having a much stronger tire will be more stable and much safer. For vans and trucks I think E rated is the way to go.
You don't have a problem until you have a problem. Much easier to avoid a lot of things right from the start.
The following 3 users say Thank You to deadwood for this post:
rvpopeye (10-19-2017), Minivanmotoman (10-19-2017), highdesertranger (10-19-2017)
