Tires, your money or your life. FYI Guidelines
8.00 16.5 were tiny.
Michelin XPS
These have steel cable casing, 16.5 recappers would likely have commercial caps still around.
Both Bridgestone and Michelin made a steer / HWY tread in steel casing.
16" rims are readily available- Single or dual.
Sidewall repairs are perfectly reliable. OTRs have far more to lose, and service is far more severe than a van, I'm sure you'd agree.
Point overall is getting lost- a rock will go through any tire- believe me. Setting tire to correct pressure, not what you think it should be-
is the key.
I absolutely know what you're doing- overInflating past all reason, then getting punctures and thinking more ply rating (and, then, more pressure) is the answer.
People could talk til their blue in the face, and you'd still do it. Jesus could come down and burn it in granite in front of you ...
The following 1 user says Thank You to UptownSport for this post:
sometimesido (10-20-2017)
i change my air pressure depending on what i am doing,basic empty load driving 36psi,going up into the woods to load 2-3 tons of wood in my 1/2 ton 4x4 45psi,snow/ice 15 psi
i bought bfg ko's and are happy with them the last set of bfg's at's last a long time until i way overloaded them and killed the sidewalls,you know firewood you need a tractor to load and can only get 3-4 rounds in the bed
cheap chinese tires are crap,if you dont recognize or cant pronunciation the name dont buy them
on my rv i have fairly new 16.5 and will most likely get 16 rims but would like 17-18 rims to have more clearance between the rim and brake drum,16.5 are failed experiment from the past
Yes, they used to say the same thing about Bridgestone, and they have it figured out.
So will the Chinese.
The '.5' series was to move away from split rims- they went to .5 or 'wide base', tubeless rims.
something became 14.5 (Mobile home)
15" (old super heavy duty moving van tires) became 17.5 IIRC
17" became 19.5"
Of course everyone knows 20>22.5 and 22>24.5
You would see those bizarre split rim sizes still in use. 16" splits were super popular, and 20", s o m e t i m e s 22"
So, 16.5 was an attempt to get away from some some split rim, I'd bet a LT 15".
They were usurped by tubeless rims for 16", which isn't a 'wide base'.
As people have pointed out, 16.5 is still used in special applications, off roaders, subset HMMWV
Split rims sucked, each manufacturer had a different ring, and some had several models that didn't interchange.
We literally had a chart on the wall!! Not to mention they needed a tube and a flap that would always fail.
Lots of beads broke, and probably still do because both tires were so common at one point-
Remember suggesting to a guy that he not put his face over a side wall when inflating.
A few minutes late, he stuck a 16 on a 16.5 and bead broke.
You hate to suggest to a man how he does his job ...
The following 2 users say Thank You to UptownSport for this post:
frater secessus (10-20-2017), Minivanmotoman (10-20-2017)
(10-20-2017, 12:25 PM)UptownSport Wrote: Yes, they used to say the same thing about Bridgestone, and they have it figured out.
Amazon recently quit carrying the Conti Motion tires I use on my commuter bike.
I bought a Chinese tire based on 4.5 stars average over 182 ratings and reports of longevity.  Spooned it on;  it's a great tire so far.    At least equal to the Continental and a good deal better than the OEM tire.  I commute 100mi on them each weekday.
frater/jason @ Quartzsite
Gulp.
By bike you mean motor cycle, or are you Lance Jr??
Was a really interesting article about Chinese finally being able to make ball point pens.
Turns out ball's metal must be very high quality, and precise, and, until now they hadn't been able to acheive that type of quality. Article said it was a sign they're coming into their own.
Think van's tires are Korean- prev owner just bought them- kinda hoping for nail truck to tip over ...
(10-20-2017, 08:22 PM)UptownSport Wrote: Gulp.
Motorcycle.  One of my father's game cameras caught me on a flyby:
[Image: riding.png]
Minivanmotoman (10-21-2017)
Many years ago in Car & Driver, they interviewed a race car driver, can't remember who, on driving advice.
Two things I remember is 1. Drive like a glass of water is on your dash. That smoothness gives good gas mileage and prolongs brakes, suspension and driveline. 2. DON'T rotate your tires as the non drive ones will last far longer than just replacing the drive ones. Found that very interesting. Obviously not applicable for Awd or 4wd, only 2wd. Made sense to me.
https://youtu.be/XDl8ZPm3GrU
Except irregular wear- Especially rears on FWDs.
Luxury car tires last the longest. Why?
Drivers are unwilling to subject themselves to high cornering forces.
(Cornering's what wears tires)
Check cracked sidewalls too! Last year I noticed my rear tires had cracks on the sidewalls (load range E btw), but had plenty of good looking tread. I was on my way out the door to the RTR so just made a note to replace them when I got back. Well while headed home from the RTR the rear tread rolled off of the tire, causing $2000 in cosmetic bedside damage to my truck.  The tire did not blow however, just tread rolled off and shredded the side of my truck.
Worst still was having to change it at night on the side of hwy 10 (driver side) with almost no shoulder and no exit for miles.
The following 2 users say Thank You to Itripper for this post:
Minivanmotoman (10-23-2017), rvpopeye (10-23-2017)
A business was making a case to convert your trailer's 16" to wide base-
They claimed the extreme side loading on tandems in turns due to axles being so close together was cause for all the 'fly aparts' on 16".
I do recall being struck at amount of lateral stress trailer tires endure under severe, sharp, low speed turns;
so i believe them.
Wide base, even 16.5s were much sturdier than most 16"
Here's one, but they only talk longevity: https://www.pjtrailers.com/options/17.5-...and-tires/
Minivanmotoman (10-26-2017)
