1993 Ford E-350 Club Wagon Transmission
Howdy mes amigos! I have issues! A seal failed in my transmission and I had some good ol' boys fix it and now ain't nothin' right. I'm appealing to y'all because I need to know how to talk to a mechanic about what happened and what is now happening so I don't get screwed too badly. I've been told I need a rebuild and I just ain't buying it ($1900).
Here's what I know (and that ain't much):
1. 76,000 miles on the van.
2. 3-speed automatic overdrive transmission
3. 5.8L V8 engine
Those is facts... now for the "what I know" that is my experience... I drove it to a dr's appt 30 miles away. It was idling high and did not lower even after warmed up. I made it to Columbia just fine, no issues except the idling thing. After the dr's appt, it didn't want to move. It felt like a semi where you're only going 25 miles an hour in 6th gear. I drove it about 3 miles through city traffic when it finally acted like it wasn't gonna finish the trip so I pulled into a gas station and got help (this is also the only time the check engine light came on and it was only a minute or two before I pulled in and shut her down). It was towed to a neighbor's house on a flatbed trailer. They dropped the transmission, replaced the seal and put it back together. A few days later it was in my driveway and I was told I could drive it to work that night, but I wanted to hear it before the guy left, so he started it up and tried to put it into gear but it was very, very hard... I shook my head knowing that if this young whipper snapper was having a hard time moving the lever, I was not going to be able to do it at all! He got it into reverse and the idling was still high, he then got it into neutral, no change in idle... then he managed to get it into drive and there was a huge clunk (I thought the drivetrain must surely have fallen out at that time) and then a loud whirring from underneath the vehicle.
Said mechanic said it was the idle and he lowered it and it does shift much, much easier now. The idle is still high and doesn't lower after it warms up. And finally, it moves in 1st gear, 2nd gear and reverse but doesn't in drive. WHAT?!?!?!?!?
He called his buddies at a transmission shop and they decided, based on his description, that it needs a rebuild. I'm not convinced. I'm not sure I can answer many questions because I am not really mechanically talented, but if this were your home on wheels, what would you say to the guys at the shop to make sure they knew what they were talking about and not trying to gouge you for money??
I need this baby to purr because she's gonna get me to the RTR in January. I'm devastated right now and it's everything I have not to just give in and take this as a sign that I'm not meant to go, but I'm pretty hard-headed too! HELP me if you can!?!?
'93 Club Wagon (Juanita) & AbuelaLoca (Belinda)
All aboard! Ha ha ha ha ha ha haaaa!
Ay, Ay, Ay, Ay, Ay, Ay, Ay
I don't think there's enough information to make any suggestion over the internet.
Your description of the semi thing could be that trans was slipping badly, or just not shifting.
The 'Not wanting to move' isn't a good phrase in a transmission thread ...
What seal did they replace, and why? They had to drop the transmission- Front pump seal?
So fluid had drained out?
And the selector lever- 'gearshift' literally wouldn't move before after their transmission R&R??
It's possible they bent the linkage, so 1 is really 2, and 2 is really drive ... Working in 'R' doesn't fit, though
And it sounds like you're indicating something catastrophic occurred with the big 'klunk', that's really not a good thing either-
To be master of the obvious
My suggestion is to have someone else look at it- Perhaps a friend or a little shop.
I'd guess if it wasn't bad before they R&R it, ...
The following 1 user says Thank You to UptownSport for this post:
AbuelaLoca (10-23-2017)
(10-23-2017, 04:03 PM)UptownSport Wrote: I don't think there's enough information to make any suggestion over the internet.
Yeah... My optimism dies hard! LOL
I like the idea of bent linkage... if the mechanic mentions something like that, I'll at least know they're hearing me and not just making a blanket decision to rebuild the transmission for $1900 when the actual work they do is not a total rebuild... know what I mean?
it sounds like the linkage is not adjusted right or like uptown said the guy bent it when removing the trans. what area are you in? maybe someone here could take a peak at it. if not you need to find a honest trans shop in your area. highdesertranger
bullfrog (10-23-2017), AbuelaLoca (10-23-2017)
Update?  Been almost 10 days...
The following 1 user says Thank You to This world isn't home for this post:
AbuelaLoca (11-03-2017)
Nothin' new. Too many other curve balls right now.
That would be the infamous E4OD transmission. Ive been through many of them. Does the overdrive light on the gear shift blink when it acts up? When it does shift, does it feel as though it slams into gear? Revving higher than normal to get to the shift point? If it does these symptoms, then it needs rebuilt. Just make sure to get a good rebuild. Most transmission shops can rebuild it with an upgrade kit, which is the best option. A stock rebuild in most cases will fail. Ive known some to go for many miles with no issue. Ive also known more that fail premature. Just like anything else, you might get a good or a bad one. Ford knew of the problem and did finally fix it it 1997. Personally, I avoid any E4OD from late 89 thru 97. They can be built to be bullet proof if you spend the money. I had a 94 F250 Turbo Diesel that went thru 4 of them in the first 80k, all covered under warranty. All they did was throw in a new one every time. The 5th one, I had rebuilt with the upgrades,  and when I sold the truck with almost 400k, it was still going strong. That rebuild cost me about $3500, but was worth it.
Kelly & Teresa
99 Ford F350 Diesel
2003 Cougar 32' 5th Wheel
And a spoiled rotten pug named Leeloo!!!
The following 1 user says Thank You to Kmmech for this post:
AbuelaLoca (11-04-2017)
(11-03-2017, 09:33 AM)AbuelaLoca Wrote: Nothin' new. Too many other curve balls right now.
Abuela, so sorry to learn of your trouble.  So frustrating, so disappointing.  I feel your pain![Image: confused.gif]
This too shall pass.  Stay centered.  You will get thru this, I feel sure.  Keep the faith!
Buena suserte,
The following 1 user says Thank You to Charlotte's Web for this post:
I just recently bought an '89 E350 class c really more of a class b+,(no over cab bunk), - runs but not very good. Reason I didn't start my own thread on this is, I have similar issues. First, idle is not right, way to low and hunts for proper speed, thinking either the map or the idle/air control valve. Second, shifting is kinda clunky, but that may be because idle is not right or it may actually be the transmission. Or, just needing a change of oil as it's been sitting for a few years. It's been on the cold side here in Ohio and I've only an open air shelter to keep it in. By open air, it's a carport with sides high enough to pull it in out of the weather, but no ends and no heat.
Yesterday I did pull the air cleaner off and bump a bit on the idle/air control valve with no effect - no improvement. I buttoned all back up and got a little depressed. Wife told me not to worry so over it, we know a very good small shop that could probably fix it right and she didn't care the cost.
The camper does have some other issues with like the generator and LP gas system, but will get to those in another thread if I have questions, WHEN I get around to those items. Getting it running right is first priority. It has less than 90K miles on it but has just not been keep up the last few years as the prior owner has been dealing with cancer and not able or willing to deal with the upkeep on a camper.
Hoping for some warmer weather, below freezing here today, but hoping does not make it happen.
  Drum brake job - 1993 Ford E-350 Vagabound 91 4,637 08-24-2017, 04:35 AM
Last Post: Vagabound
  Hesitant starting / misfire problem - 1993 Ford E-350 Vagabound 23 1,089 08-14-2017, 11:00 PM
Last Post: slow2day
