Dicor lap sealant
Installing one roof vent ... is one tube enough.. two? What do I use to seal the shore power inlet on the side of the van?
I'm never lost... I'm exploring alternative destinations.  Rolleyes
(11-05-2017, 06:25 PM)bpdchief Wrote: Installing one roof vent ... is one tube enough.. two? What do I use to seal the shore power inlet on the side of the van?
We just installed a roof vent on our fiberglass high top, and used Dicor Butyl tape and one tube of lap sealant. Hope that helps! They also have “no sag” sealants that may work for the shore power inlet!
-Born2Explore
https://www.youtube.com/channel/UC91msO0...huja2wiMWQ
2004 Extended GMC Savana G3500 w/ Hi-top
200 Watts of Solar, 140 Amp Hour Battery Bank
The following 1 user says Thank You to Born2Explore for this post:
bpdchief (11-05-2017)
always use butyl tape first. the marine stuff is the best. if nobody posts a link for it I will try to find my link. on the roof vent butyl tape then screw the vent down then use the self leveling sealant. after a couple of days check for 100% coverage add more if needed. on the side use butyl tape only. highdesertranger
Dicor has a none self leveling variety for use on vertical surfaces.
