Window replacement help in Florida..???
Not just a poor choice.. If you saw the inside you would cringe..can the whole window be removed and metal replace it with a gasket kinda thing? And just put a good window in the sliding door ?
I have a roof vent which I will eventually attach to a solar panel .
Spark...
The Shift Chick
All who wander are not lost !
* Gina  - 1994 Ford Cargo
Gypsy - 1988 Ford Tioga
1998 - Plymouth  Grand Caravan..
Or the window replacement it's not plexi.. But it's better properties. Which keep the heat / cold out
Spark...
The Shift Chick
to properly get rid of the widow a piece of sheet metal would need to be welded in. not an easy or cheap job. however for a temporary fix you could remove the window and get a piece of sheet metal larger then the opening and use something like 3M VHB tape to cover the opening. I wouldn't count on it as a permanent fix. highdesertranger
(11-07-2017, 03:50 PM)highdesertranger Wrote: to properly get rid of the widow a piece of sheet metal would need to be welded in.  not an easy or cheap job.  however for a temporary fix you could remove the window and get a piece of sheet metal larger then the opening and use something like 3M VHB tape to cover the opening.  I wouldn't count on it as a permanent fix.  highdesertranger
Mmm... That doesn't sound wise or safe.. Think I'll sit tight...ID rather have Windows then ..I just am not able to do it by myself.. I'm 62 ( ugh hate saying that) and physically it's just not an option
Spark...
The Shift Chick
what's not wise or safe? the 3M tape is not going to fail. highdesertranger
(11-07-2017, 06:57 PM)highdesertranger Wrote: what's not wise or safe?  the 3M tape is not going to fail.  highdesertranger
Ah... Okay .. However I would rather put windows in and make it look better I can always black out the windows..I am on a very limited budget so I'd rather do this just once .
Spark...
The Shift Chick
Shift Chick - I'm working on getting you some help there!
What is the make/model/year of your van?
Does it look like the window openings were there before - as in it had stock windows in the beginning and someone replaced them with the jalousie windows?
Are there more than just the two of them on the passenger side - ie is there stupid stuff on the driver's side or back as well?
highdesertranger (11-08-2017)
(11-08-2017, 04:39 PM)Almost There Wrote: Shift Chick - I'm working on getting you some help there!
Wow... Thank you soo much.. I've included the other picture .thought they were included before sorry..
She is a 1994 Ford 1500..
From what I see on the inside..I don't  believe  there were stock Windows..
Spark...
The Shift Chick
(11-09-2017, 08:05 AM)Shift Chick Wrote: Wow... Thank you soo much.. I've included the other picture .thought they were included before sorry..
From what I see on the inside..I don't  believe  there were stock Windows..also the windows are bolted from the outside and a frame of wood to support screens (pretty ugly)
Anything else you need to know ??
Spark...
The Shift Chick
That was not done by any professional.
  Plexiglass window replacement WheelEstate USA 4 3,078 04-29-2014, 06:28 PM
Last Post: WheelEstate USA
  Conversion van window replacement...How? DollarJoe67 3 1,736 06-26-2013, 05:45 AM
Last Post: ilovemyvan
