Back to the shop...again
So, here is the story...
I broke down just past Green River yesterday in the early afternoon.
I called GoodSams (my roadside). They claimed there was no tow company within 100 miles that could handle a rig my size. (This is total garbage...at just 21 ft...everyone can handle this......the truth is that no one would do it for the price GoodSams would pay...remind me to find a better roadside.... these folks are supposed to handle RVs...and this is a little one!)
So, GoodSams calls me back and tells me to call 911. No kidding.
UTah highway patrol finds a tow company all the way over in Selina ..they want $1000 CASH to tow BUT, they would only take me to their facility in Selina! I could have ended up stranded in freezing temp there! I want them to tow me to Green River....nope...they need lots of extra money to do that! But, in Green River I could have had a friend come and get me and the kitten.
That was all they found. Again..total garbage
I called the tow company I used before over in Grand Junction...they agreed to come and bring me all the way back to GJ for $850. So..back to Simpsons garage. Got back late last night.
My friend in GJ is letting me stay on the couch once again.
So..this morning....went to Simpsons. What they found....the hose for the transmission to the radiator to cool the fluid was totally split! It was labeled explicitly for propane! No kidding. The jerk in N. Carolina (shop in Sanford) that put in the new radiator put this in! This was never going to hold...the temps far exceed what that hose could handle
Most of the problems I have encountered has been the sloppy workmanship of so called professionals. Who does that? Knowing what was going to happen....where is honesty and pride of work gone?
So...now back to the same problem I was having in August. This is not the transmission.
This is the engine cutting out. Just a little at first, then more and more...till I cannot even get up to 25 mph. Finally dies.
There is all of the following installed NEW in the last 9 months.....
Water pump, upper fuel pump, lower fuel pump, fuel line, radiator, all new hoses, A/C compressor and all new hose lines, new transmission, new manifold, new heads (all of them) new ignition switch, new ignition control module, new distributor, new master computer, new alternator, new ignition coils
Not to mention new breaks..rotors, pads, master cylinder, fluid and break line. New shocks and struts, new d-link, new control arms, new bushings, new exhaust, new muffler.. Let me add here...there is no cat-converter. I learned this a couple months ago...it must have been removed sometime before I bought it in Florida. As there is no inspection, I never put a new on in.....for more then $1,000...I simply could not afford it.
The only thing I can think of that isnt new....gas tank and bottom of engine.
So..I think that old gas tank is the problem. I wonder if there is lots of "junk" and sludge that clogs the pump filter and causes this.. How might I figure out if this is happening?
Anyone else have an idea?
The following 1 user says Thank You to RoamingKat for this post:
JustACarSoFar (11-15-2017)
if that was the case you could just change the filter and be good until the next time it plugged up. one thing this is not an internal engine problem. without me being there it's really hard to put my finger on it. please forgive me but I don't remember what drive train is in this RV? highdesertranger
I do not know the answer to that. It is an E350. 460 engine.
The pump in the tank has a filter on it. It was replaced back in Mid Sept. so, in keeping with your thinking...this may be why the problem "appeared" to be solved....that is..until the new pump/filter clogged. ??
Dang.
Sad
Roamingcat with the trans cooler hose split did you loose transmission fluid or was it just the outer layer of hose split. When you say you broke down are you referring to cutting out and not able to go above 25MPH until the motor died? Ignition spark can easily be checked with a timing light and primary power with a test light. A fuel pressure gauge can allow you to see fuel delivery problems as it will go low or flutter. I have on some older vehicles installed these so I can observe them from the driver's seat when looking for intermittent problems. If power source is a possible problem I make a temporary harness so I can get back to the shop. If fuel delivery problem a boat tank with electric pump and a splice I can plumb easily with a power source. I have gone so far as to install multiple fuel and electrical systems that I could easily switch over to keep from being stranded. It doesn't take too many $1,000 tows to justify these measures. Would the engine not restart after it died? Gumout Carb Cleaner burns better than gasoline. Spraying it into the intake manifold can identify a lack of fuel problem. At this point to identify the problem or problems should be the main focus. Anything you can do to help will be worth the effort as mechanic's time is costly.
and the year?
well whoever changed the in tank pump should have looked into the tank to see if there was a problem with the tank.
highdesertranger
It is a 1988
The in-tank pump was done by the same guy that did the propane hose instead of one for transmission fluid. I have not found the shop name in my mountain of paper work...but he is in Sanford, NC.
so it's a Ford drive train. I suspect the ignition control module, I know you already changed it. make sure they are using high quality replacement parts. if they are using cheap junk parts you are no better off then before they were changed. BTW has anybody thought about hooking a fuel pressure gauge up so you can see what it's doing when it starts acting up? highdesertranger
bullfrog (11-16-2017), RoamingKat (11-15-2017)
That is insane. A 21' class c is just a 21' van with a little overhang. Any 1.5 ton (F450) wrecker could pull that thing. Crew cab 1 ton dually pickups are that long or longer. I had a 22' 1982 class C so I know...
I'd be calling up bad Sam corporate and screaming bloody murder about this. They claim to be an RV tow insurance/roadside insurance company and I know from the RV forums many people with 40 foot diesel pushers have Good Sam.  You need to pursue this if you have the stomach for it.
I'm so sorry that you got taken by the parts replacers who are not mechanics, and by the cheapskates who throw on any old thing just to get you out the door knowing that you wont be back.
I'm not enough of a shade tree mechanic to help you however back in the day it was always spark, points or fuel that caused issues like you describe. Spark (loose bad wiring) doesn't sound correct, neither does a bad ground. Points probably isn't it as that year 460 was fuel injected, wait, a 1988 is usually a 1987 drivetrain on rv's so I think 1987 was the first year for fuel injection on the 460.
I'd go with fuel filter, fuel pump or what HDR said.
The following 2 users say Thank You to This world isn't home for this post:
JustACarSoFar (11-15-2017), RoamingKat (11-15-2017)
Well.... the ignition control module has been changed more than 4 times since Sept. 1. At first we thought they were burning up. But, then we found out that once they were cooled back down...they stopped failing.
The last time, the module was relocated and placed with a heat sink due to the over heating issue Ford acknowaged back in 1992... that was the fix...which is still in use. So the mechanic changed this over....replaced the master computer and the coils at the same time. But..that problem had totally different symptoms. The engine would cut out..but..the total electrical systems would cut out with it. This time it was just the engine...just like back in August.
So..at my request, the fuel tank was dropped today, and the tank and lower pump inspected. The tank is in good shape...so is the pump.
This problems has not happened since the end of August...and did not repeat today. Hooking up a fuel pressure gauge sounds good..but the problem has not been repeatable. Yesterday was the first time this issue occurred since the end of August.
I am very sure that Simpsons is using the best parts available.
I am thinking maybe I will sk Simpsons to install a fuel pressure gauge...and I will stay here in GJ for a couple more weeks and drive it around..a lot...hope to catch it failing.
