  • 2 Vote(s) - 5 Average
Big Blue version 4.0 build
Big Blue version 4.0 – It’s getting exciting
http://www.van-tramp.com/wp/big-blue-ver...-exciting/
In my last blog post I was waiting for a single part to finalize the interior walls and ceiling. It was just a simple antennae wire that I needed to put in place before I buttoned up the ceiling boards, which had a domino effect on everything else that could not be buttoned up. Once that wire was in place – the day after my last blog post – things started taking off. Here comes the fun stuff!
First was to install the fridge as all else in the van would be built off the fridge location and placement. Kerri and I finalized some adjustments to the placement and built out the simple cabinet that would house the new appliance. In the last iteration of Big Blue, the fridge sat at ground level, making it not-so-easy to load or unload, and damn near impossible to find that one item you wanted buried deep in without having to lay on the van floor. This time around it is raised to a more manageable height as well as relocated immediately behind the driver’s chair. Well, not immediately behind. This time, I left just enough room for that chair to be rotated 180 degrees and actually  used by someone… with legs. Under the fridge goes the Lithium battery, the 120 volt smart-charger, and a safe large enough to hold our valuables while we are out on a hike.
[Image: IMG_2408-229x300.jpg]
Once the fridge cabinet was placed in Big Blue, things started getting exciting. The main counter top and cabinet w
as the next project. Forty six inches long, and 20 inches deep, the cabinet was a big one. It would not only hold nearly all the food and other supplies, it would also be the home to the new sink, faucet, foot pump, and water jug. But first, my very elementary cabinet making skills had to make something large and square enough to work. It was the ‘square’ part that I have a problem with. Making all the necessary joints and angles line up has never been my strong point. Luckily, the rubber floor is quite forgiving and allows me to be slightly off here and there and the floors will conform to those mistakes. Another good reason to have a rubber floor when one is a beginner cabinet maker.
Since the fridge has been raised, the large counter was split into two pieces and tiered. This prevented our window from being blocked by the butcher-block counter top while still allowing the fridge cabinet to be taller. Not only is that cabinet taller, it is also four inches deeper to handle the large appliance.
Next came some basic divider walls. Some of these would give a structure for the over-the-counter shelf to attach too. Others would function as a closet (in the rear of the van). Each divider wall had to be cut – from two very expensive pieces of wood – and custom cut to match the curves of the interior wall and height of the ceiling, all of which changed for each divider wall. Scribing out a 6 foot curve was painstaking, and scary. One mistake and the entire thing would be a waste. I had been mentally practicing  my scribing method over the past few years in anticipation of this day, and I am happy to report that all four pieces fit great.
[Image: IMG_2411-1024x576.jpg]
Two of those divider walls still needed to be trimmed down to their final state. By removing some of the material it would open up the van without losing the support that will hold the shelf in place. It was as simple as taking a half-triangle-shaped bite out of each wall so there was a line of sight from one side of the counter to the other.
On the following day I added in some additional framing for the drawers and cabinet doors, shelves for the closet, and cut a large circular hole in our butcher block counter top where the sink would be inserted. Things are starting to looking like a usable van again (not vanagon!).
[Image: IMG_2422-1024x768.jpg]
Big Blue would have finally have some basic plumbing and the ability to brush teeth (or wash hands) without having to spit out the door. Always a plus when your neighbors are nearby and judgey (judgee, judgie, judge-ee? Oh who knows!).
Kerri not only hates anything pre-manufactured, she has one hell of an eye for unique looks and design. It was her idea to make the faucet out of copper pipe, which would match the antique hand crafted copper mixing bowl that we re-purposed into a sink. The end result is not only spectacular, it is one of a kind, and will certainly be a talking point when we give tours. A foot pump – nearly hidden in the corner of the two differently sized cabinets – would suck water from our new tank mounted under the van and through the faucet – hands free! The sink will drain directly into a container under the cabinet which can be emptied by hand.
[Image: IMG_2423-282x300.jpg]
Over three days of Kerri’s hard labor, we removed all the newly built cabinetry to cut the facing for the cabinets, then prime and paint it all. While she worked tirelessly on the paint, I worked on framing out the bed/couch and stove top cabinet. It then took another day to install all the newly painted cabinetry into the van and complete all the battery hookups – because, once that sucker is in place, it is buried under the fridge and I really do not want to have to get to it again.
[Image: IMG_2426-248x300.jpg]
Funny story (not really); I built the damn bed 1.5 inches too short! There would not be enough room for the portable toilet that needs to fit under the bed due to the mistake. I was measuring from the wrong point, and that is what I get. It was an easy enough fix though… just add a 1.5 inch board to the entire frame underneath to raise it. There, I fixed it!
This really completes the main “building” parts of the van. Now it is all the details (arguably more taxing and time consuming) of drawers, doors, and adding the finishing touches. Drawers and doors, that is the next task.
A few more pictures of this past weeks work…
[Image: IMG_2428-1024x768.jpg][Image: IMG_2436-1024x682.jpg][Image: IMG_2437-1024x802.jpg]
Traveling since 2010 - My BlogMy Van
The following 1 user says Thank You to Van-Tramp for this post:
tav-2020 (12-13-2017)
Wow! Looks great. Love the kitchen and that copper sink!
tav-2020   http://tagalongvagabond.com
The following 1 user says Thank You to tav-2020 for this post:
Van-Tramp (12-13-2017)
wow I mean WOW. copper sink, butcher block counter tops. dang, looking good. highdesertranger
Yeah, what He said..
Wow............
There is a difference between my personality and my attitude.
My personality is who I am, my attitude depends on who you are.
2 amazing dogs and Miles the 1987 Dodge B250
I live in the Uncanny Valley
The following 1 user says Thank You to GypsyDogs for this post:
Your van really looks professionally done, you two are very talented. Trimming the divider walls makes such a big difference, and your color choice not only makes the visible wood pop but also brings the refer in to the decor as opposed to being just an appliance. Great idea with your sink and fixture as well, another item that looks good with your wood top. Are you going to screw in a short nipple with the end cut on an angle to control the water flow? Water flowing from the open elbow will be sloppy, although an aerator may work here. I expect to see your completed van in a magazine and most definitely someone will feature you folks in a video. Very nice work, very clean.
Cheers, Rick
The following 1 user says Thank You to rm.w/aview for this post:
I'm definitely watching this build. I see you're using R Max to insulate? Probably one of the best improvements you can make. Cool
(12-13-2017, 09:49 AM)rm.w/aview Wrote: Your van really looks professionally done, you two are very talented. Trimming the divider walls makes such a big difference, and your color choice not only makes the visible wood pop but also brings the refer in to the decor as opposed to being just an appliance. Great idea with your sink and fixture as well, another item that looks good with your wood top. Are you going to screw in a short nipple with the end cut on an angle to control the water flow? Water flowing from the open elbow will be sloppy, although an aerator may work here. I expect to see your completed van in a magazine and most definitely someone will feature you folks in a video. Very nice work, very clean.
Thanks!
The faucet is literally just a 1/4 inch plastic tube in the copper pipe. It pumps in from a 1/2 tube and goes to 1/4 inch after the little foot pump... so more pressure shoots out the tip of the faucet then you might think. It is more like the dentist faucet (small stream) good for brushing teeth or washing hands, nothing more.
rm.w/aview (12-17-2017)
I am so jealous, and it looks so big!
Great, Great job..... Dbl Wow!
On the journey of a lifetime!
Well thought-out all the way around and a nice job on all your designs including the paint scheme.
You can always tell when that special collaborative effort is working well together.
(12-13-2017, 06:16 PM)Van-Tramp Wrote: The faucet is literally just a 1/4 inch plastic tube in the copper pipe. It pumps in from a 1/2 tube and goes to 1/4 inch after the little foot pump... so more pressure shoots out the tip of the faucet then you might think. It is more like the dentist faucet (small stream) good for brushing teeth or washing hands, nothing more.
Genius! Conserving water while having good pressure, all tastefully concealed.
Cheers, Rick
Van-Tramp (12-18-2017)
  Big Blue version 3.0 Van-Tramp 61 11,773 09-25-2014, 04:03 PM
Last Post: LeeRevell
