Front end vibration Dodge Grand caravan
My Dodge Grand caravan has recently been a strange vibration in the engine, or possibly dash?thst is growing stronger. I can't really feel it when driving, but in drive sitting at red lights it is very strong, and is growing stronger. Is there any kind of respect online that informs of common minivan problems that I could consult before seeking a mechanic? I am very worried about getting cheated by mechanics. I just have no idea where to start. This is probably the greatest area of fear in my life. I love my minivan so much, but live in dread of her at the same time.
Capricci
1. fancy, whimsy, caper
2. sudden start, motion, or change of direction
4. one old, blue minivan, destined for greatness
No service or check engine light?
What's your major city? Motor mounts come to mind first. Might be throttle body (use Chemtool for throttle body) or injectors -- buy some Seafoam injector cleaner for the gas tank, see if that helps. Caravans have vibration issues all stemming from a number of issues.
How old is your battery? Have a load check done.
Have you replaced anything with the van recently?
Grab a drink and read this thread about caravan issues: https://www.cargurus.com/Cars/Discussion-t4367_ds463681
Thanks! I don't really understand most of what you said, but i will look at the thread and Google all those things. O or maybe YouTube them.
Capricci
O. No check engine.
Capricci
when was last time for tune up and oil change? more info would help too, such as rough idle , trying to die out etc...
The ring on harmonic balancer would come loose.
You could jack up the passenger's side, remove front wheel, and pull splash guard off, and inspect.
They made C-vans by the bushel. SOMEONE is going to have a problem with SOMETHING on the vehicle, so don't let people freak you out by all the reports-
Not helpful.
Overall, a vibration at idle doesn't rate high on problems that scare me- If it's performing fine otherwise.
Mine has 225k now, and has delivered excellent economy and reliability.
It could be as simple as needing a tune up. When I first read tittle I thought motor mount but then I read it did it when you were just sitting there it threw that out for me. I have had a few bad motor mounts on vans. I would say if you haven’t had a tune up in a while try that. If you go to a mechanic and they can’t guarantee that what they want to fix is the problem then go to another one. Sadly I got sick of repairs on mine and sent it to the junk yard in September. It had less than 135,000 miles on it. But the vibration can be common and can happen with age. That is one problem I wouldn’t worry to much about.
Sounds like one of your motor mounts may have gone bad. They hold the motor to the chassis of the van, and are basically large blocks of rubber to reduce vibration from the motor to the van itself. Once one goes bad, then it stops the vibration reduction. You would feel this vibration more at lower-engine-speeds then higher.
If your motor seems to be running normally (not sputtering or surging) then my bet is on a motor mount. Unfortunately, the easiest way to determine that is with another set of eyes; In Drive (foot firmly on brakes), one person go watch engine (lift hood first of course, do not stand directly in front of van) while the other presses the gas firmly (keep other foot hard on brakes). The engine should move slightly, but not jump around in the engine compartment. If it moves more than an inch or so, the motor mount is your problem.
Good luck
Traveling since 2010 - My BlogMy Van
The following 1 user says Thank You to Van-Tramp for this post:
Capricci (12-17-2017)
