Experience w/ Renogy AGM Batteries?
Does anybody have experience with the Renogy AGM batteries? They seem to be considerably cheaper than other AGM batteries with similar capacity.
  • Deep Cycle AGM 100AH (12v) = $199
  • Deep Cycle AGM 200AH (12v) = $390
They have minimal reviews on Amazon and haven't found much about them elsewhere. It appears that they have a 2yr warranty, which is a decent start. Thanks in advance...
Upon looking closer it looks like the the 200AH capacity rating is based on 10 hour rate... Most other batteries are rated using the 20 hour rate, correct? Could this be the culprit for the lower price... It actually has less power than a 200ah battery @ 20hours?
Soon-to-be van traveler...
Ford e250 Conversion Van
A 10-hour rate should show lower AH than at the gentler 20-hour rate so in this case their error is being conservative, surprised marketing let that slip.
The 12V battery market in North America is 99.99% scammers. I doubt those are truly good quality for deep cycling purposes. You should be able to easily get the detailed tech info on these
specific charge profile, trailing amps definition of 100% Full, equalization if appropriate,
storage discharge rate vs temperature
charts on these like DoD% vs lifetime cycles (scrap at 80% SoH) or
SoC% vs voltage at different discharge rates, accurate to two decimal places
etc. If not then you should be able to call the **manufacturer** - which will not be Renogy - and speak to a qualified engineer in tech support.
I'd bet good money these are not available.
IMO Lifeline, Odyssey and Northstar are the only makers of good quality mainstream true deep cycle AGM in the US market.
They are expensive.
Flooded (FLA) batts are **much** better value, even the cheapest will last longer than those Renogy, at ~$180 per 200+AH locally.
I only recommend buying AGM if you have a real need, like the install location requires mounting batts lying on their side.
frater secessus (12-27-2017), free2enjoy (12-27-2017)
Quote:Could this be the culprit for the lower price... It actually has less power than a 200ah battery @ 20hours?
It works the other way around; 200AH in 10 hours is harder to do than 200AH in 20hrs. It is unusual for a battery company to report only the 10hr rate; 20h is standard for deep cycle batts. I'd guess the information is wrong, based on the clearly confused "owner" comments on the Renogy page.
Reviews on Amazon are mixed, but the reviewers don't seem particularly well informed. I'd guess they are plain jane Chinese AGM rebadged with the Renogy logo. I'm not knocking that, btw.
BTW, the 200Ah battery weights 129lbs.
frater/jason @ Quartzsite
And with lead batts you **want** heavier weight per AH.
Lighter weight means poorer quality wrt deep cycling lifetime.
That's why pairs of 6V is convenient, the best battery value by far is Duracell (actually Deka/East Penn) FLA deep cycle golf cart batteries, available at BatteriesPlus or Sam's Club
For 18 months, 16 months full time, I’ve used the VMax batteries that Renogy sells. 3, 100 Ah, and they’ve worked flawlessly. I use a CPAP every night (using Schumacher 410 inverter) and power a 50 qt Dometic refrigerator at 35 degrees. Also the barebones 3 speed manual Fantastic roof fan. My batteries have never gone below 12.5. I use 3, 100 w Renogy Eclipse panels. On bad sun days I recharge them with a generator and Vmax 20 amp, 7 stage Smart charger. Takes approximately 3 hours.
Bob
2016 Ford Transit 2500, 130" WB, Mid roof
Full time since Aug 2016
The following 2 users say Thank You to BobBski for this post:
frater secessus (12-27-2017), rvpopeye (12-27-2017)
Bob
Good review !
What are the settings you use on that charger ?
Stay Tuned
popeye
(12-27-2017, 12:20 PM)John61CT Wrote: IMO Lifeline, Odyssey and Northstar are the only makers of good quality mainstream true deep cycle AGM in the US market.
They are expensive.
Thanks John. My thought was similar. Seemed too good to be true for an AGM. I'm leaning towards either 2 Trojan or the Duracell branded 6v FLA batteries for the value. I've read differing perspectives regarding ventilation for FLA - any insight/experience on the need for that? I expect to have consistent air movement in my van between a fan & open windows, but I understand that technically speaking FLA batteries are supposed to be vented directly to the outside.
Some people are sensitive. For me, don't mind if I smell it crack a window for a while.
Just make **very** sure they're secured from moving in an accident and non-conductive cover to prevent shorting.
If fully enclosed, then you *have* to vent, careful no sparks.
H rises so maybe a flex tube from a top corner to outside, or where you're already venting out, like a fridge.
My understanding is the only time they gas is when they are being charged, so less of an issue for sleeping hours.
-Douglas Tooley
My Blog
  Renogy batteries climbing coastie 12 547 08-16-2017, 10:31 AM
Last Post: Weight
