Coleman stove-Computer Heat pipe heater
BTW, does your screen name EL34 have anything to do with the audio tubes?
EL34xyz (12-31-2017)
Brilliant, and your presentation was well done. Love your build out.
The following 1 user says Thank You to FinallyFree for this post:
(12-30-2017, 05:18 PM)tx2sturgis Wrote: BTW, does your screen name EL34 have anything to do with the audio tubes?
Yes, my business is Tube amp building supplies for vacuum tube guitar amplifiers
I used the name EL34 in games going back to mid 90's
Quake 3 was probably the first time I used it
So I have been using it ever since on forums Smile
Howard Dumble comes to mind Santa Cruz not far from me. Do you do mods?
Sorry that was off topic.
The following 1 user says Thank You to wagoneer for this post:
Cool...I have a few EL34 and EL84 stereo amps, is the reason I asked...
I even have a review of a little tube amp published over on Tube Depot.
Well small world.
Ok, back to pipe heaters and heat pipes....
Tongue
(12-30-2017, 09:25 AM)tx2sturgis Wrote: What about the teflon coating on that pan? Did it melt? Scorch? Burn?
Back when I first got my RV and heated with the stove on low, I found that turning the burners down really low, sometimes the flame went OUT. Now you have raw propane being emitted.
I'll stick to using heaters for heat and stoves for cooking.
(12-31-2017, 07:04 AM)wagoneer Wrote: Howard Dumble comes to mind Santa Cruz not far from me. Do you do mods?
No, sorry, only tube amp parts
http://hoffmanamps.com
I thought I would do another test this morning of the stove heater
BTW, my van is in my driveway, I don't live in the van Smile
I meant to get out early when it was 13 degrees F but I forgot
It was 23 degrees F when I entered the van and 23 F is the high of the day
I set the stove flame on low and the 12 volt stove fan on high so it would blow the heat away to the side faster
One hour later is was 44 degrees F in the van
Pretty good considering the entire interior shell keeps radiating cold and it's way harder to bring up the temp from a very low temp like that
It way easier to maintain a temp or bring the temp back up a bit if the interior has already been warmed up previously
Anywho, just throwing out info here if case anyone wants to try this, modify it and take it a bit farther
May I suggest, if you have a similar day, to run the test over without the computer parts, just the fan blowing on the pan. I am curious if there would be any difference since the flame is a constant and the only source of heat.
Yes, we need to plan a man in a van with a fan blowing on a pan.
lol....and I hope his name is not Stan.
Tongue
Shocked
(01-01-2018, 02:21 PM)gsfish Wrote: May I suggest, if you have a similar day, to run the test over without the computer parts, just the fan blowing on the pan. I am curious if there would be any difference since the flame is a constant and the only source of heat.
I don't think I am not going out to the van today, it's 5 degrees F right now  Undecided
Also, I don't want to take my rig apart
It has thermal paste between the pan and the aluminum block on the heat pipe which gets messy and I don't have any more of it on hand
I probably have several old mother boards and computer cases with 12 volt fans
Most like a bunch of people here do also
If someone else wanted to try that....
You would have to set the fan off to the side away from the heat because they are plastic
And you would have to raise it up and aim it at the pan so you did not blow out the burner flame
And somehow hold it in that position so it did not vibrate around and move
