Anyone tried a hammock in a van?
(12-30-2017, 07:40 PM)WanderingCanuck Wrote: Seems like a valid point.  I'm thinking it might enable me to build out an interior slower than would be needed with a traditional bed.  If I could figure out a design that keeps fixed items to opposite corners it might work.
With valid anchor points I can see a hammock on the center line working, especially with extended vans. In this video, Jamie has her hammock being used as a seat, (hammock shows up at minute 12:35). https://youtu.be/arUe540Kqfc   Hammocks are cooler to sleep on during hot weather, and when drawn tight are incredibly comfortable!
Cheers, Rick
Thanks for all the links and input. It seems very doable, if not for the long run at least for the short term.
I have 3 years of hammock sleeping in a van. First year in a full size dodge, last three years in a Toyota minivan.
I love all the floor space it frees up and also being level is less important.
A towhee is a type of sparrow. I am also called Nancy.
WanderingCanuck Wrote:I'd love to have them pointed out because my search for "hammock" didn't yield anything obvious.
Here ya go.
frater/jason @ RTR 1000ft E of main camp on "dark blue" road
gargoyle (12-31-2017)
(12-30-2017, 08:31 PM)rm.w/aview Wrote: With valid anchor points I can see a hammock on the center line working, especially with extended vans. In this video, Jamie has her hammock being used as a seat, (hammock shows up at minute 12:35). https://youtu.be/arUe540Kqfc   Hammocks are cooler to sleep on during hot weather, and when drawn tight are incredibly comfortable!
My  van isn't extended or a hi-top. Honda Odyssey. All rear seats removed.
My hammock hangs diagonally across the rear cargo area.
You don't pull a hammock tight. The sag is what works best, for a number of reasons. Then your body lays diagonally.
Hammocks are cooler..the air can get around under you . But this is also something to consider in cold temps. I have the proper insulation and have slept in the hammock to sub-freezing temps.  Last week was -19* in Michigan and I slept fine. I ran the heater prior to bedtime and when I woke up at 6am.
If needed the hammock flips out of the way in seconds and the entire cargo area is free for whatever. Try that with a big bed frame. The hammock weighs 1 pound, which saves me gas.
I custom made the hammock to fit the dimensions of this van. Cost $5 in Walmart materials.
WC, there are a few vids on youtube where the people run a strap over the roof and into the rear hatch and passenger door. You can try that for a quick and simple setup. The straps will allow water in during a rain. So, its a fair weather set-up.
Been a fulltime hammock sleeper for over 2 years now here at the house. My Hammock is a 11ft gathered end style. It is big and by far the most comfy for me being six foot tall. Everybody is different and it took me a little while to find out what works for me. Most important is to lay somewhat diagonally and not inline with the Hammock. The lay gets much flatter. I use a pillow for my knees and a small pillow for my head. Sleep better than I ever have in a bed and my wife is happy also since I snore and am in a different room. (stayed up all night one night to see if I snored and I didn't) Smile
-Mike
Life is tough. Its tougher if you are stupid.
You can ignore reality, but you can't ignore the consequences of ignoring reality.
2017 Dodge Ram 1500 reg cab 5.7L Hemi and 1993 18ft Kit Road Ranger 5th Wheel, 200w solar.
Yeah, it's a great idea! I have a pull out bed/sofa in my van and anchor points to hang a hammock when the bed is folded up. It can get chilly since there's nothing underneath you...I put my sleeping bag in.my hammock sometimes and that's pretty cozy but not a permanent solution for cold weather.
If you do want to have a hammock in your van, you need to design around it so none of your furniture will get in the way when it's hanging.
Sent from my Nexus 6P using Tapatalk
It continues to sound like a viable solution.
As for the cold, if I'm planning to insulate the living space very well and have a gas furnace (propane, gasoline, or diesel) for temperature control, does this issue go away? I'm aware of the difficulties of using a hammock outside in cooler conditions but wouldn't think this would be a problem inside where I control the temperature. I suppose if I wanted to run things cooler at night the same would still apply.
If you put the insulation/sleeping bag under the hammock, snugged up against it, then the issue of compressing it with your weight goes away. A regular blanket can work as well for this, you just need to gather the ends a bit looser than with the hammock, and it doesn't have to be as long. Another way is to have a large sleeping bag and slip the hammock inside it, so that the bottom of the sleeping bag is below the hammock and the top is above you. Leave the bottom of the sleeping bag unzipped for the end of the hammock to go through. The primary idea is to have the insulation under the hammock, not between you and the hammock.
1997 Thor Windsport 34' Class A
http://shadowmoss.blogspot.com/
(12-30-2017, 07:37 PM)WanderingCanuck Wrote: How so?  Just in terms of having to extricate yourself (safely) from the cocoon-like confines of the hammock, then get yourself nestled back into it?  I can see how this would be more difficult than just throwing back the covers on a more traditional mattress.
It was hard for me to get out of when half asleep since I'm a bit hefty and have back problems. I tried using a urinal but the hammock squeezes you into a position where that doesn't work well.  I also have a problem with a knee that doesn't extend well because of a botched ACL repair, so that was a problem,too.
The swaying, rocking-cradle sensation is great and I had planned to add some kind of electric motor driven cam action device to my van's suspension to keep the slight sway going all night. Like wave action while sleeping in a boat. Oh well....
1993 Ford E150 conversion
