Starting while cold
2000 ford E150 5.4L V8
Just want to see if this might be nothing more than a vehicle aging, or if its about to have a serious problem.
Yesterday for the first time, the van wouldn't turn over, just acted like it wanted to. I panicked because I'm not mechanically inclined at all.
So eventually I just give it some gas while trying and it starts up. It had been pretty cold the entire day, and the van was turned off before that early early morning around 3am after wife got off work and it was even colder out then.
Anyways, once it was started it ran normal like it always does. Left it running as we had to run in town, after about 45 mins we had to shut it off to run into a store, came back out, it started fine. Went to a friends house, the car sat for about 2 hours, and started back up fine. I head home, and then the van would have been sitting off from the hours of 8pm to 3am. This time when I went to start it, it once again didn't want to start right up, but as soon as I pressed on the gas it did.
the van is 17 years old and I understand these things happen. It hasn't never had this issue before, though I can't say for sure that it has endured cold like 7 degrees. We are leaving to head south today. I just want to know if this is common with cold weather or if this is going to be a possible growing issue, in which case I hope we can make it to the rtr and have someone fix it.
Instagram: ellocoburrito
In my experience the extreme cold and higher altitudes will bring out some interesting symptoms and noises in vehicles. I'd keep a good eye on it, but not worry too much either! (Especially if you are heading South).
Maybe time for a tune-up on the van soon? Holler if you have any trouble on the road!
Wink
https://tinyurl.com/y74tm6pa
Proud YARC inductee
Its Definitely in need for a tune up! My own fault for putting it off. Thanks man, hope to see you soon!
The following 1 user says Thank You to WanderLoveJosh for this post:
Van Man Dave (01-01-2018)
(01-01-2018, 08:58 AM)WanderLoveJosh Wrote: Its Definitely in need for a tune up! My own fault for putting it off. Thanks man, hope to see you soon!
That's probably all it isWink   Looking forward to seeing you all too! Safe travels! √
Proud YARC inductee
The following 1 user says Thank You to Van Man Dave for this post:
WanderLoveJosh (01-01-2018)
when was the last time you changed the fuel filter? another common problem on those that cause that issue is the idle air control valve. when you say you have to depress the gas pedal to get it to start, that points to the idle air control valve. highdesertranger
Idea Pick up some tune-up supplies and I'll help you stick 'em on  Cool
Proud YARC inductee
(01-01-2018, 09:26 AM)Van Man Dave Wrote: Idea Pick up some tune-up supplies and I'll help you stick 'em on  Cool
That would be awesome!
What all do I need and we will pick it up??
(01-01-2018, 09:16 AM)highdesertranger Wrote: when was the last time you changed the fuel filter?  another common problem on those that cause that issue is the idle air control valve.  when you say you have to depress the gas pedal to get it to start,  that points to the idle air control valve.  highdesertranger
I’m the worst van owner ever, I started getting a bunch of stuff done to it this year, but put off some of the basic important stuff. This morning it was cold but it started pretty good, didn’t have to press the gas this time, but had to turn it a second time.
well if it's due for a fuel filter make sure you do it. highdesertranger
(01-01-2018, 06:25 PM)WanderLoveJosh Wrote: That would be awesome!
Like HDR suggested, a fuel filter would be good option. I always keep an extra on hand anyway  Spark plugs may be worth changing out if they haven't been done recently. Air filter may need attention too. Throttle body and PCV valve cleaned.... The list could go on a whileWink
I'd check the owners manual for some ideas on what else may need attention. All depends on what you may have done to it in the last few years too.
Proud YARC inductee
