Mattress platform condensation
Trying this stuff, Let you folks know.
http://www.fisheriessupply.com/hypervent...pads-39-50
1975 Ford E-100, 351W, C6, 9" rear....300,000 miles and counting.
Working every day toward someday not working another day.
For years I've known that it's not a good idea to put a mattress directly on the floor. For years I've forgotten why that was. This thread reminded me, so thanks. Smile
So, I have a couple questions to go along with the theme of this thread. First, would one of those vinyl (waterproof) backed mattress covers prevent mattress moisture? I know it would at least remove the human body moisture part of the equation.
Second, I'll probably be building one of those pull out platforms that is slatted so that if needed the bed can be full sized, so I'm wondering if the natural small gaps between the slats would be enough to prevent moisture when it's not pulled out? Opinions?
(03-05-2015, 11:21 AM)anewbiewannabe Wrote: For years I've known that it's not a good idea to put a mattress directly on the floor.  For years I've forgotten why that was.  This thread reminded me, so thanks. Smile
The slats will do the job just fine! The moisture is only going to form if the area under the bed frame becomes significantly colder than the area above ie the mattress. You'll need to leave maybe a 1/4 inch between each of the slats anyways, that should give enough ventilation to prevent any condensation issues. But if you get it, one of the easiest things to do is to put in cabinet doors for access to the storage area and then leave one or more open at least a crack.
IIWM, I wouldn't be using one of those vinyl mattress covers. Having experienced their discomfort while in the hospital, there is no way I would use one. Yuck to sleep on, all the body heat and sweat just stays right at your level and won't do anything for the condensation at the underneath of the mattress caused by warm mattress meeting cold from below the bed frame.
(03-05-2015, 12:40 PM)Almost There Wrote: IIWM, I wouldn't be using one of those vinyl mattress covers. Having experienced their discomfort while in the hospital, there is no way I would use one. Yuck to sleep on, all the body heat and sweat just stays right at your level and won't do anything for the condensation at the underneath of the mattress caused by warm mattress meeting cold from below the bed frame.
I found a nice vinyl-backed mattress pad when my daughter was little that worked really well in case of accident and wasn't the typical vinyl yuck, but I'm not fond of them myself. I have breathing issues now so low to no VOC is the way I have to go so I'm not even sure what I'll be doing for some kind of padding to sleep on.
I'll most likely have sliding doors for the permanent storage areas underneath if for no other reason than to keep things in place during travel. Depends a bit on whether I can fabricate what I want for a reasonable price. I'll be taking a page out of my dad's book and basing the doors on how he put doors on the cabinets in our old van we camped in when I was a kid.
(03-05-2015, 01:21 PM)anewbiewannabe Wrote: I found a nice vinyl-backed mattress pad when my daughter was little that worked really well in case of accident and wasn't the typical vinyl yuck, but I'm not fond of them myself. I have breathing issues now so low to no VOC is the way I have to go so I'm not even sure what I'll be doing for some kind of padding to sleep on.
My van came with what the owners' daughter termed a 'rustic' interior....haha, yep rustic it was. Rolleyes
Just as a warning - the first thing I noticed about the cupboards was that the sliding doors rattled like crazy going down the road. There's a reason that RV's come with regular cabinet doors with latches. If the sliders are loose enough to move easily, they're loose enough to rattle. If it were in a trailer you wouldn't notice it but in a van, you'll hear it every mile of the way!
The other very loud noise on the road was from the drapery track...he'd used regular household metal I channel track...the ones that you use the plastic rollers on..talk about noisy!
I never noticed a noise from the doors Dad built, but maybe that's because the cabinet was also my seat in the van so maybe my weight kept em tight. Tongue Then again, he did the same type door for a cabinet in the family room and perhaps it was because he had the doors so tight they were challenging to open! LOL I've still got that old cabinet from the family room but it's way too big for a van.
The nice part is that the doors I'm thinking of aren't integral to any important design functions so I don't have to put them in until I can figure a way to cheaply test out my ideas. Depending on how quick I'll have to get moving when the time comes I may rely on bungees for a while. Big Grin I just know I'm a nester and need to cater to that part of me to successfully live in a van. Since I can't have my rainbows and flowers on the outside I'm gonna let my my colors fly inside. (Meaning I'm so tired of living in a house painted for resale I want a bit of color in my life even if the outside of the van is white. ROFL)
(01-24-2013, 03:15 AM)wrcsixeight Wrote: Slats would help, but compromise strength, depends on how you build/support the bed platform.
Think about how regular mattresses and box springs are built,  Those little"speakers" by the mattress handles and the box spring covered in a airy fabric and open to the bottom.
http://www.defender.com/product.jsp?path...id=1818021
Too bad this stuff is so expensive for what it is.  I bet it would still enjoy some forced air circulation.
I'm sure some thick coarse wool would help isolate the mattress from the cold platform
Unsealed plywood would absorb the moisture and mildew/mold spores.
I made a bed frame for a truck I lived in back in 1990 or so, out of 1x8 and 1x4 lumber. Four 1x8s screwed together using drywall screws made a basic box, then the 1x4s (about eight of them as I recall) were placed VERTICALLY between the side 1x8s. On top of this was a canvas-covered foam mattress, which was about 8" thick, so it stuck up above the top of the frame by about four inches, which was no problem. I had no issues with strength nor condensation. Best bed I ever had, in fact. I designed it with a rope-and-pulley system so I could pull it up to the ceiling during the day to use a table and chairs under it, but I ended up leaving it down (about 32" down from the ceiling) almost all of the time, since I spent very little time in it during the day.
1993 Toyota chassis/cab box truck (work in progress) (perpetually)
I saw a note about hypervent a few posts back... We're liveaboards in the Chesapeake bay. The nights can get pretty cold, and like most boats (and RVs), we don't have much insulation. We do have shore power though, and with shore power comes an (a drum roll please)...
ELECTRIC BLANKET!!!
Oh glorious warm berth... After shivering in the salon (I exaggerate), we go into the aft cabin and slide into the pre-warmed bed and skoosh down into warm blissful sleep.
Only one problem. The blanket keeps the warm air trapped against our skin. That's its job. So where does the humidity and air actually go? Down into the mattress. And, if the mattress is resting on the cold fiberglass, it condenses into water and BANG. The cabin starts smelling like a dank mildewy basement.
We went with Den-Dry mattress underlay. It lifts our mattress about three quarters of an inch above the fiberglass, and lets the air move freely, carrying the humidity away before it can condense, and what little does condense on the fiberglass evaporates easily, because it's not soaking into the mattress.  Once we put it down, no more problems. It's like Hypervent, but stiffer, cheaper and has cross-channels for ventilation in both directions.
