Good morning - Printable Version
+--- Thread: Good morning (/showthread.php?tid=32006)
RE: Good morning - travelaround - 05-28-2020
Yeah.. my skin is crawling less these days as I'm getting used to it. A lot of properties in this town are somewhat derelict... having mainly been built to house people working in the mill back when that was open. I think it closed in 1995. I feel so good about the clean and painted closet, it is like a very small first step toward feeling like I can get a handle on all this, one small step at a time.
RE: Good morning - desert_sailing - 05-28-2020
Well... Good Morning  everyone!
Last nite was my first to sleep in the van. It is almost ready for the road and so I will be practicing for the next few weeks to work out the kinks.
I was super excited, felt like a big adventure. Weather was great but a little chilly and had to grab an extra blanket. It will take me a little bit to adjust to a 4ft wide bed. My in house bed is 80 inch wide.. I felt like I  was on an edge all nite.... I will be redefining the meaning of sprawl out.
A couple things to add to list...a cushioned foot stool with wheels to stretch out while sitting and wheeling about, screens to keep the visitors I had out. I don't much mind spiders in the corner but the flying critters is where I draw the line. 3a tap led lights are garbage. I need to get the strip lighting installed and use my solar bank to run. Battery powered  lights could get super expensive.  Unfortunately I  didn't make my  cushions with much awareness.. and now need to get velcro or something so when they are in bed mode i don't fall between the crevices. I could have made just 4 cushions.. one for each bench(2) and one for each back (2)..  instead I was brainless and made 8 cushions total...lol... I made 2 individual for each bench and back.... LOLOLOLOl .
Anyhow.. we will see what little adjustments that need to be made after tonight. 87 degrees at 730pm... its gonna be plenty warm tonight I think.
What little things did you need to adjust after your first couple nites?
RE: Good morning - bullfrog - 05-28-2020
It has been said many times a good bed which gives a good night's sleep is the most important consideration in a build. A comfortable place to sit and a way to poop and pee are a close 2nd and 3rd but both can be done outside much easier than sleeping undisturbed in a comfortable bed out of the elements.
(05-28-2020, 09:00 PM)bullfrog Wrote:  It has been said many times a good bed which gives a good night's sleep is the most important consideration in a build.  A comfortable place to sit and a way to poop and pee are a close 2nd and 3rd but both can be done outside much easier than sleeping undisturbed in a comfortable bed out of the elements.
My head is basically at the back doors.. a few inches away. I will be putting some of kind of padded fabric/vinyl/leather there. Right now it is painted wood and metal... not very comfy or snugly. I see that the sleeping area should have been#1. I had hygiene as number one.. followed by sitting with  sleeping in 3rd.... sleeping has gone up very fast in placement.. it will be on an equal with shower and potty.. as number one after a few days of falling through the edges.
RE: Good morning - maki2 - 05-28-2020
Eva foam is the perfect material to put over the metal on the back doors. It insulates, sound deadens, its a closed cell foam and of course it also cushions. Yoga mats are made from it, the interlocking puzzle floor mats are made from it. Quite a few camping pads are made with EVA foam. I insulated the ceiling of my vintage fiberglass trailer with it using the version from auto upholstery sources that is called Landau Foam. It is also used as a thin, decoupling, sound absorbing layer under the click together plank flooring material. But that floor padding is too thin for any decent insulating or cushioning.
So the thickest is going to be the puzzle mats or the really thick exercise/camping pads. The Landau comes in a variety of thicknesses, the yoga mats will likely be a little too thin for a lean against cushion.
(05-28-2020, 09:50 PM)maki2 Wrote:  Eva foam is the perfect material to put over the metal on the back doors. It insulates, sound deadens, its a closed cell foam and of course it also cushions.  Yoga mats are made from it, the interlocking puzzle floor mats are made from it. Quite a few camping pads are made with EVA foam. I insulated the ceiling of my vintage fiberglass trailer with it using the version from auto upholstery sources that is called Landau Foam. It is also used as a thin, decoupling, sound absorbing layer under the click together plank flooring material. But that floor padding is too thin for any decent insulating or cushioning.
Sounds like the prefect headboard. I am guessing I can adhere some snuggly fabric onto those? Some blue velvet???..LOL
I think I have seen those at walmart?
RE: Good morning - maki2 - 05-29-2020
(05-28-2020, 10:25 PM)desert_sailing Wrote:  Sounds like the prefect headboard. I am guessing I can adhere some snuggly fabric onto those? Some blue velvet???..LOL
you can use the various spray glues and contact cement on EVA foam. Just check the manufacture's website for compatibility. But I have used 3M high strength 90 with it. The high strength 90 takes the high heat of putting head liner and padding against the roof of a vehicle.  If I was building a head board then I would add some snaps or Velco to the headboard so that I could attach something like a quilted pad on the surface. That way when it gets dirty that removable layer can go into the washing machine.
Oh boy, mini road trip coming up tomorrow! My workshop mate invited me to go on a long drive to go look at some property his son is interested in buying. He son is about 1,000 miles away but wants to buy some property with a large barn type building on it. He has two travel trailers and wants to have a home base that he owns and a place his dad can also use as a home base on land for his workshop. Of course I could also use it when needed to work on projects.
It is a very small town we are headed to so not likely to be much of anything open and the town park only has portable toilets which likely to be locked up with the Covid 19 situation. So we will travel in my Honda Element which is a great little "self contained" camping car. But we won't be staying overnight, just a several hour drive each way. It will be nice to get out of town even if only for a little while.
RE: Good morning - desert_sailing - 05-29-2020
Well gooood morning people!
2nd nite (87 degrees) and I see why a fan is desired.  Once I put up the black outs, the air flow stopped more or less and the whole place became stifling.
I really don't want to cut a whole up top nor do I want the noise. ugg
I bought velcro for the cushions.. did not work at all. I am going to look at the toppers today..
The black out curtains kept me from waking at 430am with the sunshine..but the heat and stagnant air had me up a short while after.
Night 3 is gonna be even better!?
RE: Good morning - B and C - 05-29-2020
The white noise of a roof vent is soothing to me. If you are ble to crack a window near you, you can get airflow over you. I crack the one by my head.
