How to minimize water use - Printable Version
+--- Thread: How to minimize water use (/showthread.php?tid=35707)
Pages: 1 2 3 4 5 6
How to minimize water use - DanielP - 03-16-2019
When I was in the scouts, we learned how to wash dishes with dirt first, then rinse with water to save on water when backpacking.
Since I plan on being limited on water when boondocking, I wonder what tips/practices/habits people have to minimum water use.  We take water for granted when living with running water,  and Ive started thinking about how should I do things differently with only 6 gallon water containers on board.  I have not seen any tips on this on any RV sources aside from personal hygiene.
Thank You,
Dan
RE: How to minimize water use - maki2 - 03-16-2019
Bob has a good video on youtube about how to wash dishes using minimal water.
RE: How to minimize water use - becida - 03-16-2019
When your water is in gallon jugs you notice when you empty one and grab another.  That leads to watching it...
I was using 3 of them a day....
When your water is in gallon jugs you notice when you empty one and grab another. I was using 3 of them a day....
RE: How to minimize water use - B and C - 03-16-2019
All pots, dishes, etc get wiped with paper towels first before stuff gets dried on. I use 90%+ alcohol to finish cleaning. Others like to use vinegar.
RE: How to minimize water use - ckelly78z - 03-17-2019
Just don't cut down on the amount of water that you drink everyday, dehydration is a killer.
Take a look at some of the flat/oddly shaped water containers/bags that might fit into spaces you wouldn't normally store anything. Learn how to conserve, but take more with you so there aren't any future issues.
RE: How to minimize water use - GypsyJan - 03-17-2019
I use vinegar in a spray bottle and wipe everything with that and paper towels.
How to minimize water use - AMGS3 - 03-17-2019
The 'Waterless hand cleaners' thread has good advice on diff ways to keep your hands clean while using less water.
https://r.tapatalk.com/shareLink?url=https%3A%2F%2Fwww%2Echeaprvliving%2Ecom%2Fforums%2Fshowthread%2Ephp%3Ftid%3D35100&share_tid=35100&share_fid=70271&share_type=t
~angie
Sent from my VS501 using Tapatalk
RE: How to minimize water use - Spaceman Spiff - 03-17-2019
+1 on water in gallon jugs; easier to handle and more obvious on the amount of water used.  When in saving mode, I use ~ 1 gallon per day for me and the beagle.
For dishes: beagle prewash, spray with vinegar/water or bleach/water mix, wipe dry.  If you are so unlucky as to not have a beagle a paper towel wipe works almost as well.
Silverware goes into a Nalgene bottle with vinegar/water mix and taken out and wiped when needed.  I change about once a week; uses about a quart.
I can shower with 2 liters of water in a sunshower.  It is a learned skill.
A pressure cooker will allow you to cook with minimal water loss.
RE: How to minimize water use - RVTravel - 03-17-2019
Minimize cooking and only eat out of 600 ml cup. Clean up is a few ml of water. That wont work for most but is my way.
