Paint for vehicle that helps with insulation - Printable Version
+--- Thread: Paint for vehicle that helps with insulation (/showthread.php?tid=35952)
Pages: 1 2
Paint for vehicle that helps with insulation - Mrsgapeach71 - 04-01-2019
Huh Help! I was watching one of the van life videos and they said something about a paint that helps with insulation. I think it was in a tan vehicle maybe an ambulance??? It looked like Bed liner paint for a truck but I’m looking for that specific brand name!!! Any info would be great!!!
RE: Paint for vehicle that helps with insulation - C-Cat - 04-01-2019
I think the lighter (whiter) the paint, the less it would heat up in sunshine, but other than that, no idea... Wink
RE: Paint for vehicle that helps with insulation - maki2 - 04-01-2019
just do a web search on radiant heat reflective coatings
Lots of claims, but not a lot of substantial data.
So far there is no magic bullet automotive paint or house paint that is truly effective for the purpose. If there were every car maker out there would be offering that kind of vehicle paint. Plus every home in south and southwest would be coated with it.
Keep your money in your pocket, you won't be getting what you thought you paid for.
Hopefully someday they will come up with such a paint. When it happens you will see all the car manufacturers and commercial vehicles using it.
RE: Paint for vehicle that helps with insulation - Sofisintown - 04-01-2019
(04-01-2019, 06:05 PM)Mrsgapeach71 Wrote:  Huh Help! I was watching one of the van life videos and they said something about a paint that helps with insulation. I think it was in a tan vehicle maybe an ambulance??? It looked like Bed liner paint for a truck but I’m looking for that specific brand name!!! Any info would be great!!!
I have seen the video you are talking about. The paint is a rubbery paint that comes in a few colors and can be tinted. It is the kind used for truck bed liner. I don't know if it is insulating, but covers nicks and dings, and prevents rust better than the conventional car paint.
The paint brand is RAPTOR.
Here is the link to the video:
https://www.youtube.com/watch?v=l5HCGTumcoA
Cheers!
RE: Paint for vehicle that helps with insulation - maki2 - 04-02-2019
it might have been "lizard skin"
https://www.lizardskin.com/recreational-vehicles.html
RE: Paint for vehicle that helps with insulation - Weight - 04-02-2019
There is a ceramic infused paint used on school busses. Just plain white house paint on the roof works as well.
RE: Paint for vehicle that helps with insulation - Matlock - 04-02-2019
I know of one application on a school bus conversion. These "Ceramic beads" were sprinkled over wet paint on the roof surface before it dried. The idea is to scatter/ redirected the suns rays. I was skeptical but when measured with a Thermal heat sensor gun it did reduced the roof temp. I don't remember the actual numbers but for that large of a surface it was deemed worth the effort.
https://www.amazon.com/ThermaCels-Insulating-Additive-Gallon-Package/dp/B01AC5KRJ6
Personally there is too much stuff, solar, wire runs, vents and antenna on my roof to bother but, may work fine for the larger roof vehicles.
RE: Paint for vehicle that helps with insulation - highdesertranger - 04-02-2019
I think the color is more important then the additives. highdesertranger
My white roof makes it 20 degrees colder inside.
RE: Paint for vehicle that helps with insulation - rruff - 04-03-2019
Marketing. It won't help. There is no way for a thin coating to provide appreciable insulation.
White exterior paint will keep your van cooler when the sun hits it, and you need foam or batts to really insulate.
