not chasing 70, now where? - Printable Version
+--- Forum: Heating and Air Conditioning (https://www.cheaprvliving.com/forums/forumdisplay.php?fid=12)
+--- Thread: not chasing 70, now where? (/showthread.php?tid=38635)
Pages: 1 2
RE: not chasing 70, now where? - MrAlvinDude - 10-29-2019
(10-28-2019, 08:35 PM)Stargazer Wrote:  Doesn't matter driving or not.  If the blanket power draw is higher than the wire rating, the wire may overheat and worst case start a fire.  Basic electrical fact.
hmmmm..... wires can indeed be over heated, by excessive loads. Most vehicles (if not all) will however have a fuse for every wire. So the fuse will blow, before the wire overheats.
I think that the overheating issue is more likely to happen in the connector.
Especially if a 12V cigi-style plugs is involved - as this style of plug does not have a vibration proofed lock-in mechanism in its design.
The 12V cigi-style connectors rely on spring loaded friction to prevent it from becoming a weak/bad/overheating connector. And this is simply not a reliable design.
So even though it is in widespread use (for historic reasons) it is often due to a weak connection in a plug, that anything overheats.
(10-28-2019, 06:54 PM)notsosure Wrote:  Does running a 12V blanket in a running auto wear your battery out faster?
If you car is running, the power typically comes from the alternator, and not from the battery. So using a heating blanket while driving, will basically not have any effect on your battery.
Many cars even come with a heating option built right into the seat.
When the car engine is however only idling, the alternator may not produce enough energy to fully power all things electrical in a vehicle, so you should not rely on an idling engine to be able to power things for hours on end.
If you need something electrical to function, for hours on end, when only idling the engine, them make sure to turn off the high power loads, like; headlights, vent air-blower, electric window defrosters, and the likes.
RE: not chasing 70, now where? - IGBT - 10-29-2019
I have found that a queen size electric blanket uses about 120 watts on the high setting (both sides together).   Since you don't keep it on full all night (it cycles anyway), typically you will use 300 to 600 watt-hr per night.   Our 3000 watt-hr goal zero yeti can thus run a electric blanket for nearly a week.
RE: not chasing 70, now where? - ckelly78z - 10-29-2019
When my 1989 Starcraft conversion van had the heater core go South during the Winter, I tried using an auxillary "automobile heater". It wouldn't stay running because the fuse kept blowing..the only way the wire would short out, or burn up, is if you had a fuse too big for the load.
RE: not chasing 70, now where? - notsosure - 10-29-2019
We in the North....well car heaters take 20 minutes to get the SUV warm....sometimes.
I guess not everyone owns a snow shovel? Wow.....we salt the road too!
This post is all over the place, yet informative and funny.
