Water faucet near Prescott, AZ? - Printable Version
+--- Thread: Water faucet near Prescott, AZ? (/showthread.php?tid=40093)
Water faucet near Prescott, AZ? - VanForNow - 05-05-2020
I am looking for a water faucet near Prescott where I can get about ten gallons of city water. I am *not* looking for purified water.
I tried calling several Mavericks gas stations in the area (in other towns Mavericks often have a faucet) but no luck so far.
RE: Water faucet near Prescott, AZ? - slow2day - 05-05-2020
Most C-stores have a sink for cleanup purposes. You probably won't be able to get a large jug under the tap but instead would need to fill one gallon jugs singly. Try to do it when they're not too busy and not all at once. Go to other stores or make a couple of trips spread out during the day..
RE: Water faucet near Prescott, AZ? - bullfrog - 05-05-2020
Just curious did you try you try the city utilities water plant?
RE: Water faucet near Prescott, AZ? - B and C - 05-05-2020
The fire department would be a good try too.
RE: Water faucet near Prescott, AZ? - flying kurbmaster - 05-05-2020
I have found water faucets outside public washrooms in parks at times ???
RE: Water faucet near Prescott, AZ? - Doubleone - 05-05-2020
^+1 Most fire departments will gladly give you water... Aside from good will, it also avoids a medic call especially in hot environments. Just don't go during meal time... Lol!
RE: Water faucet near Prescott, AZ? - maki2 - 05-06-2020
see if there is a Prescott area dog park open. They typically have water faucets. No doubt the people drinking water fountains in the park will be turned off but they might have the standard garden hose faucet remaining functional. But you will need to take your jug to the faucet.
If you need to fill a larger sized container then head to a pump out station and ask if you can fill up your jug(s) without purchasing pump out.
RE: Water faucet near Prescott, AZ? - vandella - 05-06-2020
where there's a dump there may be water. Some might be closed due to the current situation. Reviews don't seem to be current. I'd call first
https://rvdumpsites.net/#!Prescott,+Arizona,+United+States
RE: Water faucet near Prescott, AZ? - jacqueg - 05-06-2020
I know you said you didn't want purified water, but Glacier water machines are at nearly every C-store and grocery store, no need to search. And they're cheap. Just sayin'.
