Charging a battery in p/u truck bed - Printable Version
+--- Forum: Truck (https://www.cheaprvliving.com/forums/forumdisplay.php?fid=28)
+--- Thread: Charging a battery in p/u truck bed (/showthread.php?tid=40202)
Pages: 1 2
Charging a battery in p/u truck bed - johnnyliberty1776 - 05-23-2020
I have a 2014 F-150 P/U with camper shell. I plan to camp out of it. Would like to know how I can trickle charge a deep cycle battery I plan to place in the bed of the truck. Can I do so from the trailer connection 7 point and or 4 point electric connectors for a trailer tow?
Thanks to Mr. Bob Wells and all you folks for the great info!
RE: Charging a battery in p/u truck bed - slow2day - 05-23-2020
A 7-pin I believe has a hot wire but the 4-pin does not.
If the battery is depleted much at all, it could require quite a flow of amps to recharge.
So you would probably pop fuses in the tow connector circuit.
Here's some more info from etrailer.com:
https://www.etrailer.com/question-30687.html
RE: Charging a battery in p/u truck bed - johnnyliberty1776 - 05-23-2020
I will be mounting a Renogy 100 w solar panel on the roof. Just thinking about cloudy days as I want to run a small frig. So, if I am driving down the road a trickle charge is going into the battery.
On the 7 pin, the pin in the 1 o'clock position is the line for the battery and the pin in the 7 o'clock position is ground. Just not sure if I connect a wire to each and run to the battery if it will work.
I'll check out the video and thank you.
RE: Charging a battery in p/u truck bed - B and C - 05-23-2020
You would be much better served installing a continuous duty solenoid to charge the aux battery. Connect one side to the alternator and the other to your aux battery (fuse required).
What do you think he means by, " you could maintain the power to the battery but not charge it."
Very helpful article. thanks for it.
Starting with a fully charged battery (by charger and/or solar), maintaining would only require a few amps. A trickle.
But using the battery overnight to power a fridge or whatever, it will be depleted and it would require a lot more amps to charge it back up.
More amps than what the trailer connector can provide. The size of the wiring and fuse is too small for a lot of amps to flow to the auxiliary battery.
Look at the size of the wire from the alternator to your truck's starting battery. It's large so a lot of juice can flow.
The wiring for the trailer connector (and fuse) is a lot smaller and can only handle a much smaller current flow.
Small wire, long distance = voltage drop. Here is a voltage drop calculator based on length and gauge of wire: https://www.solar-electric.com/learning-center/wire-loss-tables.html/
Continuous duty solenoid...I'll need to educate myself on that as it sounds good. Does it meter electric to the battery much like a solar charge controller?
It connects your alternator to the aux. battery so it is charged as you drive.
Usually connected with 4 gauge cable for high currents.
