VanDweller Community Forums
  • Home
  • Blog
  • Forums
  • Gatherings
  • Store
  • Find a Campsite
    • Arizona
      • Moving Camp to Cottonwood, AZ
      • Camping in Quartzsite, Arizona
      • Gorgeous Camp near Wickenburg, Arizona
  • How To Articles
    • How to Choose a Vehicle
    • How to Stay in Touch
    • Cooking and Meal Suggestions
    • Simple Kitchen Tips
    • Staying Clean
    • Laundry in Five-Gallon Buckets
    • Getting Rid of Stuff
    • Toilet Options for Van Living
    • Living on the Road with Pets
    • Staying Healthy & Fit
    • Safety for the Solo Traveler
    • Homesteading for Vandwellers
  • Electrical
    • How to Have Electricity
    • Cheap & Easy Ways to Get Electricity
    • Installing a Cigarette Lighter Plug
    • Installing an LED Light
  • Heat & Cold
    • Dealing with Heat and Cold
    • Warm in Winter/Cool in Summer
  • Solar and Wind
    • Basics of Solar Power
    • Solar Power Demystified
    • How to Install Solar Panels
    • Installing Flexible Solar Panels
    • Solar Panels on a Fiberglass Roof
    • Installing a Wind Generator
    • Solar Hot Water & Electricity
    • Stealth Solar
    • Cooking with a Solar Oven
  • Van Conversions
    • How to Live in a Conversion Van
    • Converting an Astro Mini-Van
    • Living in an Ambulance
    • Living in a Class B
    • Living in a Pop-Top Class B
    • Dodge Sprinter Conversion
    • A Couple in a Van
    • Living in a VW Vanagon
    • Family Vandwellers in a VW Westfalia
    • Easy Van Conversion
    • Inspiration: Charlene’s Story
    • European Vandweller
    • Steve’s Van Conversion
    • Dodge High-Top Conversion
  • Other Conversions
    • Living Out of a Prius
    • Living in a Boat
    • Full-Size SUV Conversion
    • Living in a Converted Cargo Trailer
    • Build Your Own Camper
    • How I Lived in a Bus
    • How to Live in a Ford Festiva
    • How to Install a High Top
    • Stealth Cargo Trailer
    • Ingenious Camper Shell
    • Living in a Step-Van
    • Survivalist Truck Dweller
  • Money
    • How to Make and Budget Money
    • Money Matters
    • Workamping
  • Philosophy
    • The Two Million-Year-Old Man
    • Embracing Minimalism
    • Needs vs. Comfort vs. Luxury
    • Finding True Freedom
    • Gaia Theory
    • Why Vandwelling is Greener
    • Understanding Carbon Footprint
    • Quotes to Inspire You
    • Christmas Dinner 2013
  • Adventure
    • Live For NOW–Not Tomorrow
    • Say “YES” to Adventure
    • Say “YES” to Adventure: I Skydive
  • Boondocking and Stealth Parking
    • Dispersed Camping On Public Land
    • Living/Camping on Public Land
    • How to Live Off-Grid in Cities
    • Where To Stealth Park
    • Tent Living Off-Grid
    • Exploring Slab City
    • Dry Camping in an RV
    • Tent Living in the Desert
    • Boondocking
  • View New Posts
  • View Today's Posts
  • Search
  • Misc
    • Portal
    • Member
    • View Forum Rules
    • Help Docs
Login or Register Hello There, Guest! Please Login or Register to gain Full Access!
Login
Username:
Password: Lost Password?
    Forum
  1. VanDweller Community Forums
  2. Life On The Road
  3. Heating and Air Conditioning
  4. not chasing 70, now where?
Pages (2): « Previous 1 2
Thread Modes
MrAlvinDude
Posting Freak
Threads: 1
Thanks Received: 22 in 18 posts
Thanks Given: 20
#11
10-29-2019, 04:08 AM
(10-28-2019, 08:35 PM)Stargazer Wrote:  Doesn't matter driving or not.  If the blanket power draw is higher than the wire rating, the wire may overheat and worst case start a fire.  Basic electrical fact.
hmmmm..... wires can indeed be over heated, by excessive loads. Most vehicles (if not all) will however have a fuse for every wire. So the fuse will blow, before the wire overheats.
I think that the overheating issue is more likely to happen in the connector.
Especially if a 12V cigi-style plugs is involved - as this style of plug does not have a vibration proofed lock-in mechanism in its design.
The 12V cigi-style connectors rely on spring loaded friction to prevent it from becoming a weak/bad/overheating connector. And this is simply not a reliable design.
So even though it is in widespread use (for historic reasons) it is often due to a weak connection in a plug, that anything overheats.
(10-28-2019, 06:54 PM)notsosure Wrote:  Does running a 12V blanket in a running auto wear your battery out faster?
If you car is running, the power typically comes from the alternator, and not from the battery. So using a heating blanket while driving, will basically not have any effect on your battery.
Many cars even come with a heating option built right into the seat.
When the car engine is however only idling, the alternator may not produce enough energy to fully power all things electrical in a vehicle, so you should not rely on an idling engine to be able to power things for hours on end.
If you need something electrical to function, for hours on end, when only idling the engine, them make sure to turn off the high power loads, like; headlights, vent air-blower, electric window defrosters, and the likes.
Find
Reply
IGBT
Posting Freak
Threads: 45
Thanks Received: 43 in 34 posts
Thanks Given: 1
#12
10-29-2019, 05:16 AM
I have found that a queen size electric blanket uses about 120 watts on the high setting (both sides together).   Since you don't keep it on full all night (it cycles anyway), typically you will use 300 to 600 watt-hr per night.   Our 3000 watt-hr goal zero yeti can thus run a electric blanket for nearly a week.
Find
Reply
ckelly78z
Posting Freak
Threads: 5
Thanks Received: 129 in 103 posts
Thanks Given: 1
#13
10-29-2019, 05:29 AM
When my 1989 Starcraft conversion van had the heater core go South during the Winter, I tried using an auxillary "automobile heater". It wouldn't stay running because the fuse kept blowing..the only way the wire would short out, or burn up, is if you had a fuse too big for the load.
Find
Reply
notsosure
waiting to be approved of by a mad world
Threads: 2
Thanks Received: 0 in 0 posts
Thanks Given: 5
#14
10-29-2019, 05:53 PM
We in the North....well car heaters take 20 minutes to get the SUV warm....sometimes.
I guess not everyone owns a snow shovel? Wow.....we salt the road too!
Find
Reply
notsosure
Threads: 2
Thanks Given: 5
#15
10-29-2019, 05:58 PM
This post is all over the place, yet informative and funny.
Find
Reply
« Next Oldest | Next Newest »
  • View a Printable Version
  • Subscribe to this thread
About Our Community
We strive to maintain a safe space to ask questions, discuss relevant topics, and support each other. All are welcome, in a car, van or RV, including full-timers, part-timers, and those preparing for, or exploring the vandwelling lifestyle
Quick Links
Reach Us
Contact Us  Meet Our team
Powered By MyBB. Crafted by EreeCorp.
Linear Mode
Threaded Mode
